Old 08-13-2019, 12:31 PM #16
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
FYI... Bad bushings on the control arms can create a wheel shake, especially when braking.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 02:30 PM #17
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
Don't forget to check your wheel bearings. I had odd intermittent wheel wobble, like a bad wheel balance, inconsistent brake pedal behavior... I always listened for bad bearings, didn't make a sound. pulled them off and had at least 1/16" play! lol
Drives like a new truck now.
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 06:35 PM #18
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Update. Drivers side brake caliper was seized. The old calipers only lasted 20k miles from when the dealership replaced them
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 01:19 PM #19
Real Name: Hunter
Real Name: Hunter
Well I’m still having steering wheel shakes between 60-70mph. The shakes are not violent just very annoying. I keep taking it back to Toyota where the tires were put on and they keep telling me the front tires were off by 10 grams and they will road force balance them again Cant figure out my steering wheel shaking. Also I keep getting told everything is “tight” up front. The shaking is very inconsistent it seems to shake for a couple minutes and smooth out and then start shaking again. Is this just a normal trait of the 4Runner?
Old 08-30-2019, 02:10 PM #20
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
What tires are you running? I've heard of KO2s having issues like this very frequently.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 02:55 PM #21
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Sounds like a tire issue.
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 03:31 PM #22
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Mine does the same thing right around 65-70. It just flutters. I got brand new tires and all new front suspension. I guess I should look into the brakes.
2006 Toyota 4Runner Limited 4wd
same problem, and same year. started immediately with new tires. have had them rebalanced 3 times. had them replaced with a different set entirely. it feels like old biased ply tires, when they flat spot. its much worse in the mornings, and when the tires are cold. not nearly as bad in the afternoon. tire guys are as confused as I am. I personally did tires for a few years, and have a good idea what it takes to make these things run smooth. this one has us all baffled.
stock size and tread tires. I couldn't feel ANY difference between the first set, and the current ones. its annoying as hell though...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 04:05 PM #23
possibly a blown shock? your alignment might be off? try jacking up each side and shaking stuff to see if anything is lose?
2005 4Runner SE V8
Old 08-30-2019, 04:41 PM #24
Real Name: Hunter
Real Name: Hunter
They are Michelin LTX ms/2.
Old 08-30-2019, 04:42 PM #25
Real Name: Hunter
Real Name: Hunter
You know mine is worse in the mornings also! That’s so strange. I have new shocks and front cv axels so can’t think of what it could be.
Old 08-30-2019, 04:57 PM #26
Real Name: Michael
Real Name: Michael
hmmm wondering if the weight just keeps coming off?
Old 08-30-2019, 05:01 PM #27
Real Name: Hunter
Real Name: Hunter
I check and the weights haven’t moved or fallen off after the past 3 balances.
Old 08-30-2019, 05:51 PM #28
nevada's Avatar
nevada's Avatar
I threw mine on the lift and ran it in gear. the wheels are rock solid. not a bit of runout. but the tires have a definite bounce to them. the tire shop is going to order me yet another set of tires. this time a completely different brand.
I was quite happy with the OE tires, and that was the only reason I went with them again.
Old 08-30-2019, 06:16 PM #29
Real Name: Hunter
Real Name: Hunter
Yea I’m thinking I have the same issue with a out of round tire.
Old 08-30-2019, 08:42 PM #30
ecally ecally is online now
ecally is on a distinguished road
I am having the same problem, same tires as you installed by Toyota about 5 weeks ago.. Had them re-balanced, but feeling the steering wheel shake again around 65-70 mph.
ecally is online now   Reply With QuoteReply With Quote
replace , seized , shakes , steering , wheel
Steering Wheel Shaking Briguy420 4th Gen T4Rs 2 12-02-2014 06:56 PM
Shaking steering wheel Rollingalong 3rd gen T4Rs 6 06-14-2013 07:12 PM
Steering wheel shaking hawaii50 New Members 6 08-07-2012 07:02 PM
Steering Wheel Shaking A10MileHusker 4th Gen T4Rs 15 10-28-2010 11:15 PM
