Old 08-30-2019, 09:19 PM #31
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Originally Posted by ecally View Post
I am having the same problem, same tires as you installed by Toyota about 5 weeks ago.. Had them re-balanced, but feeling the steering wheel shake again around 65-70 mph.
Interesting. Mine were installed in June. Well if it does happen to be a out of round tire I’m wondering if I can or should switch to a different brand.
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 08-31-2019, 06:38 AM #32
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Originally Posted by DEF4Runner View Post
It might very well be the calipers seize. I too recently had a small highway steering wheel vibration. I lived with it for a while and because the pads were going, I went to replace the rotors and pads. Found one of the caliper pistons on the inboard pass side was completely seized and the same inboard piston on the driver's side was starting to seize. Replaced the calipers and viola! Rides smooth as glass now.
Thank you NAPA Lifetime warranty! ;)
Good luck!
I had calipers fail (stick) on the front brakes on my 2005 4runner - 150,000 miles.
Best to buy the new remanufactured ones as if you can't free the caliper pistons or you don't get it right - the pistons will stick again.
Calipers rust tight. https://www.amazon.com/CCK03115-Prem...Toyota+4Runner
A bad front wheel bearing will cause steering wheels jitters and pull.
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 12:06 PM #33
Real Name: Hunter
Real Name: Hunter
Cant figure out my steering wheel shaking
Well after 4 times of rebalancing at Toyota they confirmed with a meter that there are hard spots on the rotors and the calipers are tapping them at highway speeds. So crazy because I just had the calipers, pads and rotors replaced 2 months ago.
Old 10-05-2019, 03:35 PM #34
Real Name: Skip
Real Name: Skip
You say that they found "hard" spots on the rotors...did you mean to type "high" spots instead???
I ask because I don't see how a "hard" spot would effect the tire rotation in any way, on the other hand a "high" spot I can see where that could cause a shimmy.
So did you get this fix?
If so what did they do to fix it?
I can guess if it is indeed a 'high" spot/s that simply "turning"/machining the rotors will solve that.
2004 Limited V8
Old 10-05-2019, 03:52 PM #35
Real Name: Hunter
Real Name: Hunter
They say “Hard spots”. My steering wheel intermittently shakes when hitting the brakes and also inconsistently while cruising at highway speeds (60-70) they said the balancing was spot on and there’s no play in any suspension or steering components. They recommended resurfacing the rotors but I’m going to take it back to the shop that I had The brake job done and have them confirm.
Old 10-05-2019, 03:58 PM #36
Real Name: Skip
Real Name: Skip
Thanks, I have a similar issue as well, but I pretty sure it's brake related as my brakes are due for replacement.
If they said "hard" spots and that "turning/resurfacing/machining" the rotors was what needed to be done, I'm sure they mean't to say "high" spots because it just doesn't make sense that "hard" spots would cause it to shimmy, especially when not using the brakes.
Please update your issue after getting the rotors resurfaced!
2004 Limited V8
Old 10-05-2019, 04:19 PM #37
Real Name: Hunter
Real Name: Hunter
Yeah I agree that high spots is probably what they meant to say. I will be getting it checked out this coming week and will update.
Old 10-06-2019, 11:51 AM #38
i also dont think they meant hard spots... & if so, what is this meter they used to determine hard vs soft spots on the rotor?
Old 10-06-2019, 01:34 PM #39
tpetsch's Avatar
tpetsch tpetsch is offline
tpetsch is on a distinguished road
tpetsch's Avatar
Originally Posted by nevada View Post
same problem, and same year. started immediately with new tires. have had them rebalanced 3 times. had them replaced with a different set entirely. it feels like old biased ply tires, when they flat spot. its much worse in the mornings, and when the tires are cold. not nearly as bad in the afternoon. tire guys are as confused as I am. I personally did tires for a few years, and have a good idea what it takes to make these things run smooth. this one has us all baffled.
stock size and tread tires. I couldn't feel ANY difference between the first set, and the current ones. its annoying as hell though...
I have the same issue myself and I have a theory I'd like you to think about: I think that in many cases the tires are balanced within spec but drive-line components are slightly out of balance. I have noticed wheel shake on the highway while going straight, but sometimes no shaking for long straight distances, then while going thru a long bend the shake goes away at some point in the turn, then I go thru another turn and the shake starts to increasingly materialize again. I believe the issue could be that the drive-line rotates at different rates in the turns and in time the drive line components line up in opposing high and low spots -no shake- than while going thru a turn the drive line components eventually meets up to a high + high, -right side vs. left drive shafts perhaps- thus exasperating drive line imbalances and the wheel shakes again at different intensities depending on where you are in terms of where the left side drive line is in relationship to the right side of the drive line. I may be crazy but the more I think about this and experiment the more I think it's got some possible relevance.
tpetsch is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 11:17 AM #40
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
you might not be crazy. mine is definitely worse going around a long curve.
also, in the last week or so, our temps plummeted. cold mornings(mid to low 40's) I have significantly less vibrations. almost none at all. in the mid to lower 50's, its very bad. 60's and 70's, almost gone, but NOT as good as when its in the 40's. so strange...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 12:01 PM #41
My 4Runner began pulling to the right now when I hit the brakes. So I’m taking it to the shop tomorrow. Maybe a caliper has been causing my steering wheel shake this whole time.
We had a shaking steering wheel in our 2005 4 runner 150,000 miles, and a few years ago.
It needed and got a new front wheel bearing, and the shaking SW is gone.
Have them look at your front lower control arms with three bushings (assembly - one on each side) and the front sway bars (2). They wear out.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.amazon.com/Control-Drive...FBM5FV59WBZCKH
tie rod $16 "Bought for 2003 4Runner. Part helped make my steering feel like new again. "
https://www.amazon.com/Moog-ES80378-...JTWY31JZYFK4GP
Our ball joints are 15 years old.
How Long Does a Ball Joint Front Last? | YourMechanic Advice
Old 11-03-2019, 05:48 PM #42
knarfwhite knarfwhite is offline
knarfwhite is on a distinguished road
I am working on a 4th gen I picked up about a month ago and I too have had intermittent vibrations. But this truck sat for years with little use so I wasn't surprised to have brake problems. So far I've changed all pads and rotors because my problem only occurred when braking. The last time I drove on the highway it just got worse after the new hardware. I am still suspicious of my front calipers because the pistons were hard to compress, the pins were very rusty, and the pads barely fit. But I also need new tires so now I'm not sure what's going on.
knarfwhite is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 10:07 PM #43
White04SR5 White04SR5 is offline
White04SR5 is on a distinguished road
2004 4runner steering wheel shake
Can y'all help me figure out why my steering wheel shakes like this?
here is a you tube video that will show what is going on...
https://www.youtube.com/watch?v=IidS...ature=youtu.be
I know that this isn't the right way to go about getting help on a forum and that i should post my own thread for my own problem but when i tried to post my own thread for this it said that i couldn't because i haven't replied to enough threads yet....? why is that even a rule? Why should i have to reply to something someone else posted just so i can be granted access to post my own questions.... i swear some forums have so many rules its ridiculous...
Anyway. Any advice or help would be much appreciated. I didn't know where else i could post this question so just decided to find the most recent thread on a 4th gen steering problem...
White04SR5 is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 10:34 PM #44
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Pull the air bag and make sure the bolt holding the steering wheel on didn't come loose. There are videos showing how to do that. Probably need some Torx head sockets. Be sure to disconnect the battery so you don't get a surge and cause the air bag to blow.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 11:52 AM #45
highly unlikely the steering wheel bolt came loose...
replace , seized , shakes , steering , wheel
Steering Wheel Shaking Briguy420 4th Gen T4Rs 2 12-02-2014 06:56 PM
Shaking steering wheel Rollingalong 3rd gen T4Rs 6 06-14-2013 07:12 PM
Steering wheel shaking hawaii50 New Members 6 08-07-2012 07:02 PM
Steering Wheel Shaking A10MileHusker 4th Gen T4Rs 15 10-28-2010 11:15 PM
