Old 07-14-2019, 09:33 PM #1
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Really Strong Gasoline Smell
I was out on some trails yesterday, and I was having a problem with a really strong gasoline smell from my 4runner the whole time.
I first noticed it on some easy dirt roads about 30 minutes after leaving pavement (any 2WD car could make it). I was parked checking a map, and it smelled a little like gas in the car. After few minutes more driving I got out to see if I could find the source, and the smell was really strong. It mostly smelled near the gas filler area, and a bit behind the car. There was no smell under the hood, under the car, or from the tailpipe (with the car off). And turning the engine off didn't stop the smell. I tried opening and re-tightening the gas cap, but that didn't help.
I was at probably around 10,000 feet (and live at 5,000 feet) if it matters. Maybe the pressure in the gas tank was high relative to outside? But opening and closing the gas cap should have equalized it.
I had the check engine light for "very small evap leak" maybe a year ago, and I replaced the gas cap then. There were no check engine lights yesterday or today, and I went for a short drive today and didn't smell anything. I haven't noticed any leaks or unexpected loss of fuel.
Could my problem be similar to this thread?
Code P0456 - When its not the gas cap
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 09:39 PM #2
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
If possible go check your Long Term Fuel Trims and Short Term Fuel Trims via a live read on a code reader and if they are pretty high like in the 20's on LTFT then it is probably a P0174 or P0171
BigMike18 is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 09:55 PM #3
Real Name: Matt
Real Name: Matt
I don't think it's coming from the exhaust. The smell is just as bad when the car is off.
2007 V8 Limited 4WD
Old 07-14-2019, 10:51 PM #4
Mr.Edd Mr.Edd is offline
Mr.Edd is on a distinguished road
Have u check the bottom of the fuel neck?
The fuel neck to the tank has a rubber gasket.
When it wears out the fumes come out.
Have u replace the fuel filter?
If u have check it. If u haven’t it might need one.
Mr.Edd is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 06:19 PM #5
hazelme hazelme is offline
hazelme is on a distinguished road
I used to think that the most difficult thing was to get rid of the smell of gas from my hands. But then I found out about an effective way. Wash your hands with vinegar to suppress the fetid smell. When you wash your hands with vinegar, it is not necessary to rub them against each other. Just spray your hands with a small amount of the product and wait for them to dry naturally. After that, you can rinse your hands with soap and water if you want to suppress the smell of vinegar. There are actually a lot more options, but for me personally, this is the best one.
hazelme is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 09:57 PM #6
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
A common cause for gas smell like that is the fuel pump hard lines rusting out.
The pump sits in a recess on the top of the tank. Water collects there and the metal lines of the pump rust.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 04-16-2022, 08:01 PM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
The fuel pump housing, tank, and lines coming off the tank are all plastic on 4th gens and almost all mid-2000's Toyotas and up. I suppose it could be possible for the frame mounted lines between the tank and the engine to be rusted out, but I feel like that'd be a noticeable issue (fuel physically leaking on the ground).
To the OP, have you inspected the EVAP Canister for cracks/damage and the vapor lines? I'd be a little shocked that it didn't set any DTCs yet, but that would be my guess as to noticeable fumes. Another thing would be to check the fuel line connections at the engine (driver's side area of the engine bay behind the fuse block) and see if those are leaking. Sometimes people jam them on wrong when they're doing an EFI service or other work and it can wrinkle the plastic coating on the lines and cause a poor seal that drips fuel.
BlackWorksInc is offline   Reply With QuoteReply With Quote
car , engine , gas , smell , strong
Gasoline smell... LandZarc 3rd gen T4Rs 8 10-08-2023 04:48 PM
Bogging/gasoline smell in cab CHEPAZ808 3rd gen T4Rs 2 05-07-2019 09:07 AM
2014 Gasoline Smell Jaan 5th gen T4Rs 8 12-29-2016 09:02 AM
Smell gasoline achha64 3rd gen T4Rs 9 08-10-2014 08:01 AM
The sweet smell of Gasoline SwiftRunner Classic T4Rs 7 01-01-2012 09:11 AM
