Old 07-16-2019, 12:05 AM #1
bachman bachman is offline
bachman is on a distinguished road
Aux fan for AC
Hello all,
I want to put an electric pusher fan on the AC condenser of my wife's 04 V8. The AC starts blowing less than cold air when she is in traffic or sitting at a light here in the Vegas summer. The system itself is in good shape, new compressor, Freon was recharged, new fan clutch and the rest of the system was checked. All work was done at the Toyota dealership. Does anyone have a wiring diagram for which wire I should tap the relat into on the compressor to start the fan when the AC compressor is running.
Thanks,
Sean
bachman is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 12:10 AM #2
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
@rigtec
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 05:43 PM #3
Rigtec?
Old 07-16-2019, 06:53 PM #4
Real Name: Skip
Real Name: Skip
Originally Posted by bachman View Post
Rigtec?
Rigtec is a member here and Akkording "mentioned" him by putting the @ in front of his username, which will "notify" Rigtec that he was mentioned in this topic and hopefully get him to view this topic and possibly give you some advice on your project.
2004 Limited V8
Old 07-16-2019, 07:15 PM #5
Akkording's Avatar
Akkording's Avatar
Yes he is an hvac expert by trade and a genius when it comes to wiring diagrams for our 4runners. Give him a few days and he will chime in soon. RIGZ where you at Boi!
Old 07-19-2019, 02:22 PM #6
Any ideas would be greatly appreciated! 😁
Old 07-21-2019, 03:03 AM #7
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
You did not replace the condenser. It might be clogged.
radlynx is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 06:02 AM #8
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
I would definitely change out the condenser if that was not done. The condenser contains the accumulator/dryer which can be changed out separately
but the condenser can get clogged or restricted.
You can use the Y/R wire coming off the pressure switch which is located on the pass side lower corner in front of the condenser.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 11:37 AM #9
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
I know you say the system is in good condition - but if it's blowing warmer air to the point your wife is uncomfortable, something is not working properly. Good advice above.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 02:38 PM #10
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I wonder if the Lexus GX470 AC fan will bolt on a 4th gen, since they're both 120 series chassis. The relay powering the GX fan is triggered by the compressor clutch + from its own relay. I can post the diagram later.
Here's the aftermarket replacement of the GX fan https://www.rockauto.com/en/moreinfo...434549&jsn=363
Old 07-22-2019, 10:49 AM #11
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Hello all,
Thanks,
Sean
Sean - are you seeing cold vent temps when driving normally? If so, you might have an air flow problem. Adding a aux pusher fan is a band aid, not the solution IMHO. If your vent temps get cold at higher speeds but then gets warm during stop lights, then not enough air is going through your condenser. Assuming everything else has been taken care of, including the proper amount of freon in the system, you need to figure out why the fan clutch isn't pulling enough air through the condenser.
Two things could be happening here: your fan clutch fluid is toast and need to be replaced or the "timing" of your fan clutch is off. The fan clutch is engaging a little too late and not when you're idling.
The viscous fluid in the clutch is replaceable and doing a search on the 'net should yield with instructions. Same thing applies for setting the timing of the fan clutch as well. I did this on my landcruiser from many threads on this topic in the IH8MUD.com | Your Online Toyota Land Cruiser Offroad Resource site, look in the 80 series section for instructions.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 10:06 PM #12
Thanks everyone! One last question... Since our fan clutch and compressor was replaced we were in Northern California and down Hwy 1 to Pismo Beach towing our pop-up. AC worked fine blew cold and we had no temp issues towing. Wasn't until we got back to Vegas in 105 to 110 degrees that the air starts to struggle. This is why I was thinking about the Aux fan. Also is there a wire that is only hot when the compressor is running that I can tap? Thanks again everyone s time and help!
clutch , compressor , fan , rest , system
