Old 07-17-2019, 07:22 PM #1
mizak82 mizak82 is offline
mizak82 is on a distinguished road
Hatch won't close FML.. any ideas?
had the issue intermediately.. then a few months ago i heard the motor get weaker grabbing the door shut.. until i couldn't get it to work on the door.. but if i closed the hook with a screw driver it would grab and close correctly..
I buy a new latch from the dealership.. install it.. now this is where it gets weird.. everything works as it should (door lock, which hasn't worked with the key in years) and the switch which i replaced a couple year back because previous one melted) if i take the plastic strip that holds the handle and revers lights(6 bolts off) and expose all the wires(reverse lights, switch, key lock.. they all work.. i put back together then they don't work...
every time i plug in the smaller blue adapter to the ECU b on the hatch my license plate driver side bulb turns on and stays on..
I've chased down every lose wire... tried every reset.. and still can't get this to work properly..
side note my hatch rear window hasn't rolled down in years, but i do get a clicking sound now after all the resets..
could i need an ECU b? I haven't seen anyone have to replace one of those..
any help is appreciated?
2007 Toyota 4runner Sport Edition 4x4, 15% tint, 1.5 inch ALL PRO spacers, de badged, Full interior LED swap (cluster, hvac, etc), plastidip wheels, blacked out headlight housing, K&N, smoker kit, carbon fiber shifter knob, carbon fiber interior wrap, diff breather mod, added VSC off mod, added Compass rearview mirror, independent fog lights, DTRL delete, zXe bulbs, Jensen VX7022 NAV head unit, back up camera, custom rear storage
mizak82 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 07:25 AM #2
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
Sounds like the wiring is being pinched or a screw is hitting the wire when the plastic trim goes back on. Very carefully and methodically place and tape the wiring in place, check functionally and then put the plastic back on one screw at a time. Put a screw in and test, repeat till done or it stops working. That should get you closer to the problem.
Direwolf82 is offline   Reply With QuoteReply With Quote
door , hatch , key , lock , work
3D Printer Ideas - Submit your ideas ! dreyday Off Topic 15 11-08-2018 11:02 AM
I'm new here...anyone close to me? sodeman22 4th Gen T4Rs 1 06-09-2015 10:54 PM
All ideas and opinions - '14 LE Build Ideas Hudge 5th gen T4Rs 16 04-10-2014 02:48 PM
WTB 3rd Gen - Striker (Open/close device for the back hatch) Sjtaylor Want to Buy/Trade 0 09-21-2011 02:14 AM
close call at Frank Raines real close t4r4life 3rd gen T4Rs 5 05-04-2011 03:18 AM
