Old 08-18-2019, 02:47 PM #1
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
Transmission whine
Has anyone have a whine sound from there 750f?
Only can find responses from gen3 forms on searches.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 03:16 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I haven't, have you check the fluid level?
2004 Limited V8
Old 08-18-2019, 03:58 PM #3
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
Most definitely. I change all fluids before needed/required.
Trans system works like it should, shifting, running, ect.
Just got this morning a low pitch whine sound, and is coming from trans area. Increases with rpm lifting.
Never heard this before or from any postings. Almost like a mild power steering sound. Yes I checked there.
Having fun's build
Old 08-18-2019, 04:05 PM #4
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
I even did a fluid level check, color is really good looking for the miles on it.
Having fun's build
Old 08-19-2019, 12:58 AM #5
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
Ok Skip, you can laugh after I type this out.
Whine was not loud enough to hear in the engine area. Dominate underneath trans area.
Broke out stethoscope and hear whirling sound from the trans forward.
Run to the store later, and my scan gauge started showing voltage flexuation.
Smoke comes out a little later, LOL.
First item I have had to replace on this ride, not bad.
More than happy to replace this alternator versus the thought of trans problem.
Problem solved!
Having fun's build
Old 08-19-2019, 06:54 AM #6
Real Name: Skip
Real Name: Skip
No laughing from me, I know how those kinds of sounds can telegraph and sound like they're coming from several places at once, glad you found the problem Leonard!
2004 Limited V8
Old 08-19-2019, 10:02 AM #7
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Problem solved!
Mine definitely has some sort of whine. I have replaced the alternator awhile back during the tbelt install and did a power-steering flush not long after that (with the correct fluid as well) and it never went away or skipped a beat. I'm thinking trans but I haven't touched it yet. Thinking about doing a fluid transfer via the cooler lines and see what happens then.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 11:57 AM #8
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
Usually the trans only make whine sounds due to low fluid level. Changing the fluid helps the function of the hydraulics.
I would recommend changing in the manor you speaking.
Having fun's build
Old 08-19-2019, 06:02 PM #9
Real Name: Skip
Real Name: Skip
When you replaced the alternator did you also check the idler pulley and the belt tensioner pulley, both of those bearings tend to whine when they're close to going completely bad?
A mechanic's stethoscope work very well pinpointing such whines and other noises, just be very careful when using one near moving pulleys and belts etc., but it can be done if you watch what your doing.
2004 Limited V8
Old 08-20-2019, 09:46 AM #10
Real Name: Michael
Real Name: Michael
Yeah I actually replaced the belt tensioner assembly AND pulley but I don't think I did the idler pulley now that you mention it. Maybe Ill do that soon and see if that changes anything.
forms , gen3 , responses , transmission , whine
Whine from Transmission? ayeyothisiskyle 5th gen T4Rs 2 12-23-2019 05:59 PM
Transmission Whine IAmTodd 5th gen T4Rs 38 12-10-2019 05:50 PM
Transmission Whine snivilous 3rd gen T4Rs 1 05-31-2013 10:01 PM
Transmission Whine Johnsonjhn5 3rd gen T4Rs 2 01-10-2013 08:53 PM
Transmission whine Johnsonjhn5 New Members 0 01-09-2013 09:48 PM
