Old 07-30-2019, 12:54 AM #16
traildog's Avatar
traildog traildog is offline
Real Name: George
traildog is on a distinguished road
traildog's Avatar
Real Name: George
@shmabs I started with the Shrockworks dual battery kit.
Dual Battery Kit for 2010-2014 FJ Cruiser and 5th Generation 4Runner
I liked that it had the bracket for the power steering reservoir built in. Even though it was designed for an Optima battery, I figured I could cut the end off and let the larger Odyssey battery extend a little passed.
Problem with this setup is the reservoir ends up rubbing against the upper radiator hose.
To get around this, I had the bracket cut from the battery plate and a small L-shaped piece of metal welded to it and then attached to the fender well further back to avoid the rubbing.
You could just trim/modify the existing bracket so it sits further back like I did and go with a different battery plate. I also had the seams along the fender well tack welded to reinforce it for the extra weight. I had read where sometimes this area would separate with the additional weight and bouncing when offload.
I plan to mount my arb compressor in the spot behind the battery. The opposite of @blackoutt 's setup
traildog is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 07:10 PM #17
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Here is the Prado tray kit I got from Australia. It includes the ps reservoir relocation bracket and hardware needed to install behind the headlight.
I think I'll give it another coat of something, the zinc plating is decent, but probably not good enough for PA winter road salt.
techno is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 06:52 PM #18
slalomnut slalomnut is offline
slalomnut is on a distinguished road
Thanks!
Thanks to everyone who replied. I decided to go with Off Grid's extra battery tray since they were local to me and it looked like the least amount of changes as well as I'm running an Odyssey Extreme for my starting battery. I'll update the post when I'm finished.
slalomnut is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 08:12 PM #19
Finished up today, well almost. Still waiting on a Deutsch DTM 6Pin DTM06-6S DTM04-6P for the ML-ACR so it's completely clean. I had to do a little modification for the Shrockworks tray and upped the rivets to 5/32 to compensate for the loss of the stock battery tray "pins" to body holds (see photo).
List of materials:
1/0 15FT red/black Windy Nation wire
Blue Sea ML-ACR (500A) – Isolator
(2) Blue Sea Systems 187 Series, 285 Series & Klixon Circuit Breakers
Blue Sea Systems Common BusBars (100A-250A)
Blue Sea Systems MEGA/AMG Safety Fuse Block
Bussmann AMG-300 AMG High-Current Stud Mount Fuse - 300 Amp Rating
UFORCE 1/0 AWG Wire Lugs 3/8 & 5/16
SELTERM UL Listed Heavy Duty Wire Lugs 3/8 (5)
Off-Grid Dual battery tray
OGE Plug-and-Play Wiring Harness for Blue Sea Systems ML-ACR
Shrockworks Battery tray
Odyssey Extreme 34R-PC1500T
Ampper Military Spec Battery Terminal, Top Post
Young4us 2 Pack 3/4'' Heat Shrink Tube 3:1 Adhesive-Lined
Old 01-12-2021, 10:02 PM #20
ClamChowder ClamChowder is offline
ClamChowder is on a distinguished road
Originally Posted by blackoutt View Post
Yes it is OGE. It was very easy. The parts were nice fit well. It was expensive but I suppose worth it for what you get. Haven't had to worry about it at all since install many miles ago.
Nice - all electronics still behaving nicely? Leaning at diving into it, after a few years of drooling over a dual optima setup. Not having the milliseconds/seconds of self-doubt if I have a dead battery camping that I charged my spare in the trunk, and can locate the jumper cables, would be worth it alone .
ClamChowder is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 10:53 AM #21
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Sold the rig but as far as I know still performing well.
I just installed a very similar setup on my new Tundra build because I missed the utility of it so much.
blackoutt is offline   Reply With QuoteReply With Quote
4th , battery , dual , gen , tray
Who makes the dual battery tray for v6? Seymore Butts 4th Gen T4Rs 5 01-12-2021 09:49 PM
Advise on Dual Battery Tray supermike 3rd gen T4Rs 19 01-12-2020 07:20 AM
FS 4th Gen/FJ Dual Battery Tray $150 Seattle,WA Trabs00 For Sale: T4R Items 0 01-31-2016 01:34 AM
Tacoma dual battery tray- will it fit in a t4r? nytefog 4th Gen T4Rs 0 08-26-2014 03:13 PM
FS: 5th Gen ABR Dual Battery Tray $200 Portland OR frosty_1 For Sale: T4R Items 5 08-06-2013 09:50 PM
