Old 07-18-2019, 04:42 PM #1
slalomnut slalomnut is offline
slalomnut is on a distinguished road
4th gen dual battery tray??
I've searched high and low to no avail. Everything I've found has been for a 3rd or 5th gen. Anyone know of a dual battery tray to replace the stock one?
Thanks!
slalomnut is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 04:48 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
I did this write up a while ago... it might help
Toyota 4Runner Forum - Largest 4Runner Forum - View Single Post - Questions: Dual Bat setup and Power Distribution block from Shrock
I used the Dirty Parts tray (says FJ Cruiser but it works just the same). It did not replace the tray in the stock location which can hold 2 if that is what you were asking about.
I've been thinking of removing this setup and selling the entire thing here, but I haven't got around to it yet. I am making a lithium setup which will be installed inside the cab.
Old 07-18-2019, 05:55 PM #3
Nice setup! Thanks. I'm really hoping to find a dual tray for the existing battery location to maximize space utilization and lower cost of cabling.
Old 07-18-2019, 06:27 PM #4
Bumbo's Avatar
Bumbo's Avatar
You ever consider just making something a little more custom?
Making a DIY tray and two smaller batteries is anther option to consider.
Nothing stops you from using a smaller battery and a DC-DC charger which is far easier to mount.
This is a nice option not a lot of people know about. Perfect for smaller fridge projects.
West Mountain Radio - Super PWRgate PG40S
Odyssey PC680 Battery
https://www.amazon.com/Odyssey-Batte...28-spons&psc=1
You can also consider using cheaper and smaller APC batteries which are designed for a UPS.
Uses alternator when the car is running.
Charges 2nd battery when car is running with 10a charger.
Switches over to 2nd when car is not running.
Old 07-21-2019, 04:19 PM #5
tellurunner's Avatar
tellurunner tellurunner is offline
tellurunner is on a distinguished road
Thanks!
Call Matt @ Off Grid Engineering in Longmont. He is extremely knowledgable and can walk you thru your options. I did the second battery on the passenger side and it turned out great.
'07 Sport
Build Thread
tellurunner is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 02:44 PM #6
Thanks! I'll check them out.
Old 07-24-2019, 01:05 AM #7
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
2003-2009 4Runner Complete Dual Battery System – Off-Grid Engineering
Off grid engineering makes an awesome complete dual battery setup but it’s definitely pricey. Can’t comment on quality- I came across their products through an Instagram add but the stuff definitely looks nice
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 02:43 PM #8
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
I used the off grid tray and built my own dual battery setup cause I wanted a cheaper relay.
https://www.toyota-4runner.org/3255206-post10.html
blackoutt is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 05:51 PM #9
From having my own OGE setup as well as knowing a handful others with their products, I can definitely say it is top notch
'07 Sport
Build Thread
Old 07-24-2019, 11:57 PM #10
traildog's Avatar
traildog traildog is offline
Real Name: George
traildog is on a distinguished road
traildog's Avatar
Real Name: George
If space maximization is your biggest concerning then the front right corner can fit a Group 34 with relocation of the power steering reservoir.
View this post on Instagram
Dual battery setup
A post shared by pathfinderkid@gmail.com (@4rnrdog) on
traildog is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 12:58 PM #11
shmabs shmabs is offline
shmabs is on a distinguished road
[QUOTE=traildog;snip[/QUOTE]
Do you have any other pictures of how you relocated your reservoir and mounted the battery? This is nearly exactly what I would like to do.
I spent some time the other night unbolting things and moving them around in preparation for a second battery and mounting my ARB compressor, so I am very curious to see more details in what you have going on.
I just followed you on instagram, I'm @garagegremlin
Thanks!
shmabs is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 01:52 PM #12
techno's Avatar
techno techno is offline
techno has a spectacular aura about techno has a spectacular aura about techno has a spectacular aura about
techno's Avatar
I'm in the process of getting a Prado dual battery tray from Piranha Offroad in Australia. It locates the second battery behind the passenger side headlight. I'll let you know how it works out.
I got a 2000 and a 2008 SR5 4x4.
techno is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 03:08 PM #13
blackoutt's Avatar
blackoutt's Avatar
I guess it also depends on v6 vs v8.
If v8 here's how I did arb twin compressor up front with second battery (heavier of the two things) at the stronger part of the inner fender.
Old 07-27-2019, 09:08 AM #14
How was mounting the extra battery tray? It looks like Off-Grid Engineering's.
Old 07-29-2019, 07:57 AM #15
blackoutt's Avatar
blackoutt's Avatar
Yes it is OGE. It was very easy. The parts were nice fit well. It was expensive but I suppose worth it for what you get. Haven't had to worry about it at all since install many miles ago.
4th , battery , dual , gen , tray
Who makes the dual battery tray for v6? Seymore Butts 4th Gen T4Rs 5 01-12-2021 09:49 PM
Advise on Dual Battery Tray supermike 3rd gen T4Rs 19 01-12-2020 07:20 AM
FS 4th Gen/FJ Dual Battery Tray $150 Seattle,WA Trabs00 For Sale: T4R Items 0 01-31-2016 01:34 AM
Tacoma dual battery tray- will it fit in a t4r? nytefog 4th Gen T4Rs 0 08-26-2014 03:13 PM
FS: 5th Gen ABR Dual Battery Tray $200 Portland OR frosty_1 For Sale: T4R Items 5 08-06-2013 09:50 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
