Old 07-20-2019, 07:47 PM #1
niz55 niz55 is offline
niz55 is on a distinguished road
Is this correct orientation on the front springs?
I have replaced ALL the suspension components up front and I mean all of it. I have gone many times over it and re torqued everything to spec.
I am getting this metal to metal clink clink clink sound when going over sharp small bumps. I have the shocks up front set to 3rd position and the car is perfectly leveled. The spring are KYB spring off of the shock /spring I bought and when the KYB shocks leaked I used the springs on the new 5100.
I am thinking the upper 2 coils and the bottom 2 coils are very very close to each other and basically touching. Could that be the problem?
Also, I installed the springs with the smaller diameter coil on the bottom.
Is this correct orientation on the front springs?-img_20190720_163240-1280x960-jpg  Is this correct orientation on the front springs?-img_20190720_163340-1024x1365-jpg
niz55 is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 09:33 PM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Double check the torque if the lower control arms. They need to be significantly tight
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 09:37 PM #3
100lbs for the lower arms.
Old 07-21-2019, 05:44 PM #4
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Looks correct.
Did you get the bushing washer intsalled on the tophat...right under the tophat and above the coil? Some one just posted a misshap in that it was missing.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 11:05 PM #5
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you want to be anal about the spring, the lower end/ cut part or spring is suppose to be facing out as what it says in the manual.Is this correct orientation on the front springs?-spring-jpg
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 11:41 PM #6
Mine had 3 bushings on each shock so I installed that way on the Bilstein. Everywhere I see the top mounts come with 2 bushings.
Can someone give me the proper order of installing the bushings and the washer.
Thanks
Old 07-21-2019, 11:42 PM #7
Originally Posted by riceandpho View Post
if you want to be anal about the spring, the lower end/ cut part or spring is suppose to be facing out as what it says in the manual.Attachment 339601
Thank you that is very helpful. Mine is towards the back not the front.
Old 07-22-2019, 02:26 PM #8
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Part i was referring to is hard to see. The lower washer.
Shock/washer/bushing/tophat/bushing/washer...then the nut.
Is this correct orientation on the front springs?-tophat-assembly-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 04-01-2021, 09:59 PM #9
Toyota.ARK Toyota.ARK is offline
Toyota.ARK is on a distinguished road
where is this from or what is the source of this instruction? thanks!
Toyota.ARK is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 12:32 PM #10
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
The 4Runner maintenance manual.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 12:45 PM #11
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Did you torque down the lower shock bolt on the ground or in the air?
eleven14 is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 01:04 PM #12
Is this in the glovebox or one you buy? Is there a pdf version or link I can get?
Old 04-02-2021, 03:34 PM #13
montijo505's Avatar
montijo505's Avatar
Should be at the top of the screen in the “sticky” threads under manual downloads
clink , coils , front , metal , springs
front upper suspension arm big bolt washer orientation sleepydad 3rd gen T4Rs 4 02-04-2018 02:51 PM
Tundra springs on 3rd gen 4runner orientation DPR64 3rd gen T4Rs 1 09-16-2015 01:19 AM
Correct grease for front IFS CV shafts kc15842 Classic T4Rs 1 12-04-2014 10:51 PM
99 3rd Gen- Correct way to diagnose if front & rear wheel bearings are bad? hawkcharmer 3rd gen T4Rs 4 10-12-2014 08:25 PM
Quick ??? front strut cushion retainer orientation? Evan B 4th Gen T4Rs 1 01-01-2013 08:23 PM
