07-20-2019, 07:47 PM
Is this correct orientation on the front springs?
I have replaced ALL the suspension components up front and I mean all of it. I have gone many times over it and re torqued everything to spec.
I am getting this metal to metal clink clink clink sound when going over sharp small bumps. I have the shocks up front set to 3rd position and the car is perfectly leveled. The spring are KYB spring off of the shock /spring I bought and when the KYB shocks leaked I used the springs on the new 5100.
I am thinking the upper 2 coils and the bottom 2 coils are very very close to each other and basically touching. Could that be the problem?
Also, I installed the springs with the smaller diameter coil on the bottom.
07-20-2019, 09:33 PM
Real Name: Elliott
Real Name: Elliott
Double check the torque if the lower control arms. They need to be significantly tight
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
07-20-2019, 09:37 PM
100lbs for the lower arms.
07-21-2019, 05:44 PM
Real Name: Derek
Real Name: Derek
Looks correct.
Did you get the bushing washer intsalled on the tophat...right under the tophat and above the coil? Some one just posted a misshap in that it was missing.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
07-21-2019, 11:05 PM
if you want to be anal about the spring, the lower end/ cut part or spring is suppose to be facing out as what it says in the manual.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
07-21-2019, 11:41 PM
Mine had 3 bushings on each shock so I installed that way on the Bilstein. Everywhere I see the top mounts come with 2 bushings.
Can someone give me the proper order of installing the bushings and the washer.
Thanks
07-21-2019, 11:42 PM
Originally Posted by riceandpho
if you want to be anal about the spring, the lower end/ cut part or spring is suppose to be facing out as what it says in the manual. Attachment 339601
Thank you that is very helpful. Mine is towards the back not the front.
07-22-2019, 02:26 PM
Real Name: Derek
Real Name: Derek
Part i was referring to is hard to see. The lower washer.
Shock/washer/bushing/tophat/bushing/washer...then the nut.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
04-01-2021, 09:59 PM
where is this from or what is the source of this instruction? thanks!
04-02-2021, 12:32 PM
Real Name: Russell (OB #9908)
The 4Runner maintenance manual.
04-02-2021, 12:45 PM
Did you torque down the lower shock bolt on the ground or in the air?
04-02-2021, 01:04 PM
Is this in the glovebox or one you buy? Is there a pdf version or link I can get?
04-02-2021, 03:34 PM
Should be at the top of the screen in the “sticky” threads under manual downloads
