Old 07-22-2019, 01:13 PM #1
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
Fixing the driver side lean..
Icon stage 2, 285/70/17 tires. Now that I have had the lift installed for about 6 months I'd like to address my driverside lean. I know it's normal, and I know it can be remedied. My plan is to raise the front driverside coilover, and install either a 10 or 15mm rear spacer (shim) by dobinson or OME. Those that have done this, would you reccomended the 10 or 15mm spacer for the driverside rear? Measurements and photos attached.
Sent from my Pixel 3 using Tapatalk
BendRunner is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 12:26 AM #2
kenley&co kenley&co is offline
kenley&co is on a distinguished road
Bumping this up to the top, also wondering the same thing.
Have a toytec lift with 5100s and adjustable coils. Never really noticed the lean till I installed an arb bumper a few weeks ago and lost about 1/2-3/4’ of life. And now the 1’ driver side lean is really prominent and annoying
Hoping it’s just a few turns with a spanner wrench and a 1/2 spacer in the back. Had different opinions from a couple shops who didn’t really even understand what I wanted...seems pretty dang simple to me. Anyhow don’t wanna resort to a whole new suspension
kenley&co is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 09:39 AM #3
USMCEngineer USMCEngineer is offline
USMCEngineer is on a distinguished road
Lean
I have the OME yellow spacer that is 10mm. I think it helped, but with the front coilovers at the same height, the rear is still a little lower. I would go for the 15mm if I were you. You will probably still have to crank the driver side more to keep everything flat.
2004 V8 Sport| Icon 2.5"/2"| RCI Skids | SPC UCA
USMCEngineer is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 10:07 AM #4
Thanks for the reply. Went with the 15mm and am going to get it installed next week.
Old 07-25-2019, 11:55 AM #5
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
I have a 1.5" left rear spacer (38mm) but I would estimate that with front coilovers set the same height that a 20-25mm spacer would be more ideal.
blackoutt is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 12:13 PM #6
Monkey Wrench Monkey Wrench is offline
Monkey Wrench is on a distinguished road
Go with a 25mm spacer, I ran a 10mm spacer and it didn't take care of the lean. The 25mm spacer evened out the back.
'08 SR5 with Old Man Emu 884 front springs, Toytec Superflex rear springs, 285/70r17 KO2, full skids and sliders from RCI.
Monkey Wrench is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 01:11 PM #7
ah shoot. Ordered a 15mm.
Edit: Found a place over in Portland that had a 25mm, ordered that. Would rather only have to do this once.
Old 07-25-2019, 01:30 PM #8
So with the spacer in the back do you crank the front coilover up the same? So if I get the 25mm crank the front driver coil 25mm as well
Old 07-25-2019, 01:35 PM #9
I plan on installing the spacer and then evening it out. I am not sure if it's exact on the measurements. I am close to 1" on the driverside so it's gotta be close to that on the front. Of course, you don't want to crank the Coilover too high.
Old 07-25-2019, 02:35 PM #10
Makes sense. I’m guessing it might need an alignment afterwards?
Old 07-25-2019, 02:50 PM #11
Yeah I have had the icon stage 2 installed for about 6 months so the suspension has had time to settle.
Old 08-12-2019, 03:36 PM #12
Who did you order the spacer from? I normally buy from Toytec because my shop uses them. Looks like they only have 0.4" or 1.5".
Old 08-12-2019, 05:29 PM #13
I went with a dobinson 15mm, adding a second 15mm on top of it this week because a single 15 isn't enough.
Old 08-13-2019, 11:18 AM #14
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
I'd crank your front up first to even things out up there, which will in turn lesson the back side height difference. Then you can find a smaller 1 for back.
You might have to lower the front a little then.
No ride is the same when it comes to how much spacer I need to level.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 03:21 PM #15
n210wagon n210wagon is offline
n210wagon is on a distinguished road
anyone have a dobinson part number handy?
n210wagon is offline   Reply With QuoteReply With Quote
15mm , driverside , lean , rear , spacer
Driver side lean octanejunkie 3rd gen T4Rs 25 11-15-2021 09:31 PM
Does your 4Runner lean on the Driver Side TOYSTRY 5th gen T4Rs 91 10-02-2019 08:46 AM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
Driver's side lean and lift Rancid13 4th Gen T4Rs 8 04-08-2014 08:07 AM
