Old 08-13-2019, 06:22 PM #16
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I tried all of these fixes.
Putting a spacer or loading the front unevenly makes for weird driving. Adding a 1.5" spacer works great except the rear wheels now move a different rates over bumps and the axle slants if you jack up the truck.
In my opinion, the real fix is to install the OME899 extra heavy duty springs in the back and be done with it. That is what is installed now on my rig. I actually like how the rear doesn't sag when you load the truck and now the suspension is firm and the truck articulates normally when on the rocks. The spacer made the truck tilt differently from one side to the other and didn't feel quite safe.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 10:30 AM #17
Monkey Wrench Monkey Wrench is offline
Monkey Wrench is on a distinguished road
I got my spacer from a forum member, but cornfed will sell single 1” spacers for $60ish. It’s well worth it to get rid of the lean!
'08 SR5 with Old Man Emu 884 front springs, Toytec Superflex rear springs, 285/70r17 KO2, full skids and sliders from RCI.
Monkey Wrench is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 04:02 PM #18
gunkl's Avatar
gunkl gunkl is offline
Real Name: David
gunkl is on a distinguished road
gunkl's Avatar
Real Name: David
funny thing - i have the 3" OME lift with medium springs, and my truck has always leaned low on the passenger side - NOT the drivers side!
on install I had them put the spacer in the front left, it made it worse! now that i've got some miles on, it's really noticeable, and when i put a load in the back or the moto carrier on the hitch the rear right definitely sags the most.
i have a 10mm urethane spacer, im thinking of putting that in the right/passenger rear. but i'm also beginning to wonder if i should be looking at adjustable lift kits.
2014 4Runner Trail Premium
gunkl is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 05:11 PM #19
It sounds like you just have defective springs or something is broken. There is no possible way that the truck could lean to the opposite side from all the weight. Both the gas tank and the driver are on the same side, that is the source of the lean. The passenger side has no extra weight at all...so how is it possible that you have "lean" on the weightless side?
2005 Blue SR5 v8
Old 08-20-2019, 11:18 PM #20
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
What's more strange, the gen5 usually dont have as much a problem like ours.
I have so much spacers on mine, it should be illegal.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
15mm , driverside , lean , rear , spacer
Driver side lean octanejunkie 3rd gen T4Rs 25 11-15-2021 09:31 PM
Does your 4Runner lean on the Driver Side TOYSTRY 5th gen T4Rs 91 10-02-2019 08:46 AM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
Driver's side lean and lift Rancid13 4th Gen T4Rs 8 04-08-2014 08:07 AM
