for the v6 motors, serpentine belt, you can use the tacoma 4.0 belt from the dealer, its alot cheaper for some reason, now gates makes a good belt, im using the green heavy duty one for my setup, might not be able to find that one, ran a dayco brand before and its works fine also.
now for the hoses, i ran the dayco stuff before, its ok, the upper one i used wasnt really that good and it started to leak a little, now i swapped all hoses out and use gates, and its been fine since, haven't seen any leaks.
also the denso radiator too, no leaks yet, i think my original one was fine, only show leak from the hoses, so i shouldnt have swapped it out.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
