Old 06-03-2019, 01:06 PM #1
AceSpades AceSpades is offline
AceSpades is on a distinguished road
Question Possible to adjust TPS on Drive by wire?
Using Torque Pro app, I found that my Throttle Position at idle is at 16%, so I removed the cover expecting to find a drive by cable type throttle body, but if course it wasn't. So my question is... is it possible to adjust the position sensor on a drive-by-wire type throttle body? I would like to to get it read under 5% at idle
AceSpades is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 01:18 PM #2
mikewhiskey's Avatar
mikewhiskey mikewhiskey is offline
mikewhiskey is on a distinguished road
The throttle position is going to vary depending on target idle speed and conditions. What you're seeing is how far the throttle is open (perecentage). These don't have a separate IAC valve, the throttle body controls idle
mikewhiskey is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 02:06 PM #3
So that means it's an absolute position. Other cars I've worked on show close to 0% throttle. And from what I know the ECU needs to see close to 0% to shut off the injectors during deceleration for fuel economy, and as I watch my O2 sensor output it keeps cycling during deceleration which indicates the injectors did not shut off
Old 07-27-2019, 05:06 PM #4
Rich G Rich G is offline
Rich G is on a distinguished road
I am having an issue where the car occasionally won’t accelerate when pushing the pedal but everything seems like its running fine.. if I restart the car it works normal. This is an 03. Is that a similar problem?
Rich G is offline   Reply With QuoteReply With Quote
body , idle , position , throttle , type
Drive by wire? BobsTrail 5th gen T4Rs 16 09-30-2023 08:15 PM
how to adjust E-brake for toyota 4 runner 2002 limited edition, rear wheel drive ?? ttooffyy 3rd gen T4Rs 16 12-05-2019 07:22 PM
Beat Your DBW (Drive-By-Wire) SprintBoosterSales Sprint Booster Sales 0 02-11-2019 01:58 PM
2001 and 2002 Are NOT Drive By Wire Tyler James Inc 3rd gen T4Rs 36 01-29-2019 09:08 PM
2001-2002 Drive By Wire Matthew Starr 3rd gen T4Rs 16 01-23-2009 01:07 PM
