Old 11-17-2019, 10:15 AM #1
T4R03 T4R03 is offline
T4R03 is on a distinguished road
Daystar lift questions
Hey guys so I've decided to go with a Daystar 2.5 spacer lift on my vehicle. Any feedback, recommendations, any of you have? I do little to no off roading and just need something to level the vehicle out after purchasing 265/70/17 Duratracs. I know I will need an alignment afterwards but does this lift change the specifications for the alignment at all or is factory spec still ok? Also will I still have front rake with this lift?
T4R03 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 10:51 AM #2
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Originally Posted by T4R03 View Post
Hey guys so I've decided to go with a Daystar 2.5/1.5 spacer lift on my vehicle. Any feedback, recommendations, any of you have? I do little to no off roading and just need something to level the vehicle out after purchasing 265/70/17 Duratracs. I know I will need an alignment afterwards but does this lift change the specifications for the alignment at all or is factory spec still ok?
Yes you will get your alignment in specs, accept Caster. It will be low #, but you can drive and see if you like it. Or you can get aftermarket UCA then you will be 100% in factories specs. I went this way once. Good luck with your lift!
ax2021 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 05:05 PM #3
Awesome sounds good. I don't think bad caster is that much of a deal honestly 😂 My gas mileage went down the drain already with these duratracs!
Old 11-17-2019, 08:15 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Bad (too low) caster makes the vehicle wander. If you're OK with that, it won't wear the tires or reduce gas mileage. However, when I put on aftermarket UCA's and increased the caster from 2 degrees to around 3.8, the highway tracking greatly improved and made the vehicle a joy to drive on the highway instead of something of a pain.
As I said, you may be OK with wandering - I wasn't.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 11:30 PM #5
Yes this is actually what is going to be. Driving not to be a fun anymore.
Old 11-17-2019, 11:45 PM #6
Awesome sounds good. I don't think bad caster is that much of a deal honestly Daystar lift questions My gas mileage went down the drain already with these duratracs!
Well like the RonJR said your driving won’t be the same. It took me 7 months to get used to it, and guess what, I didn’t. Now I’ve got my OEM shocks laying in my basement with $400 worth spacers on the top of it. Changed All suspensions with UCAS , now what I am calling driving. Don’t waste your money on spacers like I did.
Old 11-19-2019, 12:47 AM #7
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Daystar 2.5 is ok. I've got it. Paired with factory struts, probably level. KYBs and it is level or slightly up depending on the day or parking spot. I have the KYB strut plus.
It is a little wandery on rutted highways, but fine for 8-hour-drives cross-country.
It's cheap and it'll look better. If you tow or put any loads, the front will point up unless you upgrade the rear or supplement with airbags. Just a matter of it previously having several inches of rake to compensate for that effect.
Next lift I ever do would likely be a real lift.
gaber6 is offline   Reply With QuoteReply With Quote
alignment , daystar , lift , spec , vehicle
Daystar 2.5/1.5 Lift Kit: Installation Questions luke87gt 4th Gen T4Rs 25 06-24-2020 09:45 AM
Daystar lift questions burgundy2gold98 4th Gen T4Rs 12 08-31-2016 11:14 PM
daystar lift - few questions kunia 4th Gen T4Rs 28 03-02-2012 02:18 PM
Daystar 1” lift questions. progress4m 4th Gen T4Rs 21 11-05-2009 12:46 PM
Daystar Lift Questions 4-Ruiner 3rd gen T4Rs 0 04-19-2006 11:06 PM
