Old 11-14-2019, 06:28 PM #1
toddtt19 toddtt19 is offline
toddtt19 is on a distinguished road
04 4Runner A/C and multi function display out. Clock only
Greetings,
I have a 2004 4Runner. Today the all the climate controls (A/C, heat) switches stopped working. They don't even light up. No power. Also, the trip computer which shows mileage and fuel range is blank. Only the clock is working. I have pulled every fuse in the interior fuse panel and also the one in the engine bay. I also checked several relays by switching known good ones around. No luck. I was reading some other threads that seemed to have a similar problem and ended up replacing the A/C amplifier which fixed their issue. As that part is over $350 I was hoping to get some advice here before throwing expensive parts at this. Photo below.
Thanks!
panel — imgbb.com
toddtt19 is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 07:36 PM #2
T4R416 T4R416 is offline
T4R416 will become famous soon enough
To be honest if this is something beyond what you’re able to do mechanically or diagnostically .. I would definitely pay for sometime at mechanic shop if you have or even dealership... usually will be able to figure this out in first 30 min or hour of diagnosis time... and will tel you EXACTLY what is needed .. before you just randomly throw 350$ on the amp..
T4R416 is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 07:56 PM #3
Thank you. I see no reason this would be beyond my ability to diagnose or repair but if it comes to it I would take it in. Hoping to get some advice from others who have had the same problem.
Old 11-14-2019, 09:28 PM #4
Not taking a shot at your ability but if you are not good with diagnosing mechanical as well as electrical wiring like diagrams etc then pay for an hour of diag. Maybe less stressful and better than just throwing $350 at the problem
Old 11-15-2019, 12:56 PM #5
I am quite good at diagnosing mechanical/electrical issues. In fact, I tend to fix most things myself successfully. With that said, often other people have already gone through a similar situation and have actual advice to give which is why I am on this forum. So again, thank you.
Old 11-15-2019, 01:22 PM #6
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Why the shot at his ability, I am puzzled ?????????
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 03:30 PM #7
Was not a shot like I said .. lol I simply said maybe if can’t figure out pay to get diag time at a shop before spending money on something to hope that’s what it is.. that’s all. Anyways that was my advice. Good luck brother.
Old 11-16-2019, 09:44 AM #8
Todd, @toddtt19 , you probably read some of the same stuff I did,
The fuse panel near the driver that you have already checked, just asking, did you ohm out the 15 amp ?
Everything else I read points to the A/C amplifier you mentioned.
Old 11-17-2019, 08:44 PM #9
Yes I did read that stuff also. I checked the fuses visually but did not use an ohmmeter on anything yet. I could do that for sure. I found a used working amplifier for $50. I am waiting for it to arrive and will update why I find then. Thanks for the feedback.
Old 11-18-2019, 09:13 PM #10
Fixed it!
Well the $50 used A/C Amplifier from Ebay arrived today. Had the old one out in 30 minutes even though it is buried in behind much of the dashboard. Plugged it in and it is working as good as new! Buttoned it back up in less than 30 minutes. Wife is happy and I saved some substantial $$$.
IMG-7607-2 — imgbb.com
IMG-7606-2 — imgbb.com
IMG-7604-2 — imgbb.com
Old 11-18-2019, 09:30 PM #11
@Seasparrow The A/C amplifier fixed it!!! Thanks for your help.
4runner , a/c , clock , fuse , working
03 4Runner Multi-Information Display Issues ID4Runner 4th Gen T4Rs 13 05-25-2021 11:25 PM
multi-function display bulbs out after head unit install Derek 4th Gen T4Rs 3 01-12-2014 01:30 PM
05 4Runner Multi Info Display showing "LO' karchner55 New Members 1 07-27-2013 08:44 AM
03 4runner, multi information display captain204mike 4th Gen T4Rs 3 11-08-2008 02:34 AM
Multi function display problem simple_guy35m 4th Gen T4Rs 11 06-07-2005 07:51 AM
