Old 08-16-2019, 12:06 AM #16
riceandpho's Avatar
riceandpho riceandpho is online now
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if i had the time and paitence, i would of do a spray on liquid deadener over the sound deadener, that should add another layer of treatment.
Spectrum Sludge Deadener: Sound Dampening Liquid - Second Skin Audio
let us know how your results turned out. i wouldnt spent my time in the engine bay. it just me.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is online now   Reply With QuoteReply With Quote
Old 08-16-2019, 10:58 PM #17
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Others have said the same, but based on my results, the wheel wells are major sources of noise. They’re essentially bare sheet metal with tires spinning who know how fast inside so it stands to reason that treating them will help. I was very pleasantly surprised at how much quieter it was today now that both fronts are done.
The best thing about listening to music now is how much more mid-range detail is audible.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 11:57 PM #18
CrimsonCountry's Avatar
CrimsonCountry CrimsonCountry is offline
CrimsonCountry is on a distinguished road
Nice! I'd considered doing something similar when I gutted mine again to redo the system last year but never got around to it. Would've been curious to see the actual db drop but perception is reality in most of these cases anyway (avoiding getting into the whole sound deadening vs panel resonance reduction of cld, this isn't DIYMA afterall lol)...especially since this isn't too expensive/time consuming to go ahead and do the wheel wells once you've already committed.
How do you like the Noico Green CCF? I used Noico 80mil myself and was surprised at how good it went on and seemed to be legit butyl to boot.
2006 SE 4.0 4WD (click for build) : Custom, de-badged floor mats...
CrimsonCountry is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 08:37 AM #19
Bluesky 07's Avatar
Bluesky 07's Avatar
100% satisfied with the value, ease of use, and effectiveness of both the 80 mil butyl & Noico green foam.
You’re right about perception as being part of how you personally measure the results. It depends on variables such as installed equipment (A/T tires for instance) and even the state of your hearing (I have tinnitus & other effects from jet engine exposure, but the results I’ve described are relative to before adding deadener so that only affects my perception overall, not the product’s effectiveness).
I also strongly believe that every little bit helps. For example, on its own, doing the A-pillars is hardly worthwhile, but as part of an overall strategy, that fraction of a decibel adds up. To take a business example, what’s a single cherry tomato worth? But years ago, an American Airlines flight attendant suggested removing them from salads b/c people seldom ate them. The company listened and the annual savings was $100K+ (at the time, AA operated over 4,000 daily flights). She got a nice chunk of that too through the company’s IdeAAs in Action program.
Old 08-19-2019, 08:16 PM #20
plutonic's Avatar
plutonic plutonic is offline
plutonic is on a distinguished road
plutonic's Avatar
Originally Posted by Bluesky 07 View Post
This series of posts explains my approach to sound deadening my truck, what I’ve done and plan to do, and results/observations to date.
Disclaimer: I understand that there are many opinions on how best to go about sound deadening. I did a lot of research before deciding how to proceed. Please take whatever info you find useful here and discard the rest.
Philosophy: I feel like layers between sound and occupants is key to a quiet cabin along with addressing noise close to the source, so I used leftover material to do places some people may ignore, for example the underside of the A-pillars, door sills, and kick panels, and inside the glove box. It’s not hard; I just take the panel, the foam material & maybe a small butyl piece for rattle dampening, and some scissors into the house and do it while I watch TV. Why? Because IMO, every fraction of a decibel makes a difference.
That’s also why I am doing the wheel wells. More on that in a later post.
Materials (from Amazon)
Noico 80 mil butyl deadener & Noico Green foam insulation. Very pleased with the effectiveness & value.
General Advice
- This is tedious work. Bring your patience.
- Metallic HVAC or dryer vent tape with a peel-off adhesive back is outstanding for covering seams such as around the panels covering the large door openings. I originally bought it for installing a dryer vent pipe but it’s perfect for this use as well.
- A short piece of PVC pipe makes an excellent flattening tool.
Doors
Most people agree that doing the doors gives the best bang for the buck if you don’t plan to do the entire interior. This was the first thing I did, with a full coverage layer of butyl & foam on both the inner & outer panels. I used a leftover plastic honeycomb yard sign to cut covers for the large openings & attached them with the tape I mentioned. This is just before adding the butyl layer to the inner front door panel.
Butyl layer on the inner rear door panel:
Important: stay within the “sunken” area and away from the fastener holes, otherwise the trim panel may not go back on.
Final layer on. Ended up having to trim a bit of it from the raised edge areas to get the trim to fit properly.
Door results: We have to start with the understanding that a 4Runner is never going to be luxury car quiet. With that said, there were two significant and complementary outcomes after finishing the doors. First, there was a noticeable lessening of noise, particularly in the frequency range that makes conversation in the car easier to hear and understand, so that’s a bonus. Second, as many have mentioned, the door treatment really maximizes speaker performance. Those two things taken together make doing the doors absolutely worthwhile.
My next post will cover the process and results of doing the rear wheel wells.
Can you tell me if a single order (from Amazon) of the Noico butyl and green foam is enough to do all four doors? Thanks!
plutonic is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 05:48 AM #21
Bluesky 07's Avatar
Bluesky 07's Avatar
Yes, 36 SF of each was enough.
Old 12-17-2019, 10:56 AM #22
gloch gloch is offline
gloch is on a distinguished road
Does any of this mitigate wind noise? I get so much wind noise on the driver's side door.
-gl
gloch is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 06:51 PM #23
Trekburt Trekburt is offline
Trekburt is on a distinguished road
Subscribed! Thanks for the great pics
Trekburt is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 12:15 AM #24
riceandpho's Avatar
riceandpho's Avatar
once you guys add a layer to the front floor areas, its alot quieter when you drive during rainy days. i can barely hear the splash at the wheel wells.
im waiting on new speaker adapters and should be redoing some of my deadening in a few days. took advantage of the discounts from tacotunes so i decide to replace my mdf speaker adapters, hopefully my 4 sheets of secondskin is enough for front and back speaker area. also trying some new soundskins rings. its replacing the fast rings.
Old 01-03-2020, 11:12 AM #25
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
Great thread! I have a box or two of sound deadening left over from other projects that I have slowly started to use in my 4Runner. The first thing I did was the inside of the hatch and the hatch plastic interior trim. Only issue was this added weight wasn't something that my rear hatch struts could keep up with. I think I went a little overboard haha.
In others experience, it seems like doors, rear wheel wells, and front floor are the best bang for the buck, does this seem right to those that have done a bit more deadening than I have?
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 11:58 PM #26
Bluesky 07's Avatar
Bluesky 07's Avatar
@gloch , doing the doors & the inside of the A-pillar trim does help with wind noise.
Old 01-15-2020, 10:53 AM #27
Good to know. Thanks!
Old 01-15-2020, 12:52 PM #28
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
This is super well done, great thread.
I doubt that I actually will get to it anytime in the near future, but man I would like to.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 03:29 PM #29
98Runner's Avatar
98Runner 98Runner is offline
98Runner is on a distinguished road
98Runner's Avatar
Loving this thread. I have a bunch of butyl based deadener and foam in my garage waiting to go in once I figure out the radio details. Sub'd!
-2007 Sport Edition 4Runner V8
98Runner is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 12:56 PM #30
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
x2, great thread.
I did everything behind the rear seat with NOICO butyl this fall on a lark and was truly impressed at how much it cut the road noise... it was like someone turned the bass up on the factory sub. I was so impressed that I ordered another round of butyl and the thicker foam to go over it and plan on doing the whole interior including the roof save maybe the floor pans.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
door , doors , makes , panels , sound
Sound deadening -- WOW!!! GrantK 5th gen T4Rs 22 12-24-2012 01:52 PM
Sound Deadening Tutorial? 004runnerLtd 3rd gen T4Rs 23 02-25-2012 06:14 PM
4th gen sound deadening drapaki 4th Gen T4Rs 5 01-02-2011 06:30 PM
Sound Deadening chayos00 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 10-29-2009 02:39 PM
Sound Deadening Help!! Tego Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-23-2009 05:44 PM
