08-11-2019, 11:17 AM
#16
Originally Posted by benztech82
Well, i installed my snorkel. It was a pain. But oh well I couldn't afford non existent safari version. Had to use a heat gun, it doesn't look nice as it was from the box but it works. I will take it apart again to refit it better so I will make some pictures. But honestly if you can afford the right stuff, go for it. The major problem of this snorkel is body lines. It almost doesn't match 4 runner a pillar and fender. But on a bright side its 167$ CAD. and it may look better after i fill the gaps between fender and snorkel with rubber door seals from local hardware store.
Sent from my Redmi 4 using Tapatalk
picture pls
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
08-11-2019, 10:52 PM
#17
This is how mine sits, i'm pretty happy with the way it came out. Like I said there are 3 options on snorkels that can work and none of them are a direct fit.
It aligned quite nice with the a pillar.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
08-12-2019, 09:27 AM
#18
Did you had to use a heat gun at all ? Also did you notice looss of power at the top end? It feels like my truck lost some. But since I used a heat gun, i think that i squeeshed inner diameter of the pipe to the point that it created a partial restriction
08-12-2019, 11:55 AM
#19
Here are some pictures from my initial installation
08-12-2019, 01:20 PM
#20
Thanks for posting the install pics. Kudos for trying it out, but I'll be honest, it looks like it's been damaged. Is it just the camera angle or is the head really leaning over a lot?
08-12-2019, 02:47 PM
#21
I didn't use a heat gun at all, I actually thought of using it to straighten the head of the snorkel but kinda of grew on me. Lots of friends had issues with branches breaking there's except me so I left it that way.
Try pushing snorkel head bit harder so it wont have that incline.
Not at all, I'd does make intake sound alot better when I floor it.
Have somebody rev it and put your hand or a plastic bag over the snorkel head to see if there is suction.
LC Prado 150
4th Gen 4Runner
1GR-FE
08-12-2019, 02:49 PM
#22
Snapped a few pics for reference.
LC Prado 150
4th Gen 4Runner
1GR-FE
08-17-2019, 05:21 PM
#23
Ok, so its not as bad as i thought initially.
To compensate for a different fender I got a door seal from amazon, also i bought 3,5 inch intermediate pipe and 90degree elbows instead of squeeshed piece that comes in a kit, also amazon, dirt cheap. Also if anyone get this kit, make sure that after gluing door seal between snorkel and fender you tighten bottom nuts first. Then it will align nicely.
08-18-2019, 12:15 AM
#24
Nice job
LC Prado 150
4th Gen 4Runner
1GR-FE
08-18-2019, 12:47 AM
#25
Thank you!
But i will take it down again in a month or so when those silicone elbows show up. I think engine is choking on that intermediate pipe.
04-10-2020, 12:35 PM
#26
Thank you!
how is it holding up?
mine has been lying around in the store for awhile. tried installing it today, realized i need a hole saw.
the kit i received appears a lil different from yours, or is it an improved design?.
Snorkel kit Fits Toyota Landcruiser Prado 120 series Petrol/Diesel 4x4 2002-2009 | eBay
thats the unit i bought
04-10-2020, 11:03 PM
#27
Originally Posted by earthrealm
Mine looks good no cracks or anything. I very happy with result. How is it different ?
04-11-2020, 09:36 AM
#28
ok, seen now, you bought some other pieces from amazon to make it better.
gluing the door seal, you talked about, am a lil confused, so you had to glue something again, what type of glue did you use?
am about ordering a 95mm hole saw, so i can start the ops. any final tips you can give me?.
am putting mine for the looks, dont plan going into deep water that the stock air intake cant handle
04-11-2020, 10:16 AM
#29
So the rubber seal has a 3m sticky tape already. I glued that to seal around the base of a snorkel to stop water accessing drilled sections of a fender and to hide gap between fender and snorkel. Oh, don't use heat gun I tried and had to purchase another main pipe. Make sure that you align the pipe and mark where the bolt holes are gonna be and the main pipe hole.
What may happen, after bolting a snorkel, it will take few days before main pipe will start flexing/adjusting to fender and a-pillar curves, so I suggest to tighten snorkel just snug at first, drive few days, then tighten all the way for best fit. I didn't drill a pillar, just trimmed the black metal bracket and bolted it to snorkel pipe only and glued a piece of rubber seal between a bracket and a pillar to stop pipe rubbing on paint.
I hope all that makes sense
04-11-2020, 10:47 AM
#30
Safari now makes a vehicle specific snorkel for the 4th gens: V6= SS445HF and V8= SS440HF.
It's not worth the headache of adapting one to our trucks anymore.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
