Old 08-03-2019, 09:23 AM #1
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
Unusual Brake Problem
Recently started experiencing an odd brake problem, searched for similar symptoms here but couldn’t find anything. Bit of history 1st.
The MIL/VSC/TRAC lights have been illuminated for some time. I’ve had the codes read on several occasions and it has consistently been the MAF sensor. Tried cleaning it, no luck, but the truck runs fine so I haven’t bothered to do much else. About 20,000 miles back the Brake warning light came on. I checked and the pads were nearing their end so I replaced all four sets, completely flushed the system with new fluid, nothing was stuck or hung up so I buttoned it all back together and while the light didn’t go away, the brakes work great, ABS engaged when needed, so again I moved on with life. FWIW I used the brake pump to bleed the rears as detailed here.
Fast forward to last weekend, we’ve had a lot of rain recently in central Florida and one morning I got in to drive to work and noticed the Brake light was gone, but the brakes were snatchy and the pedal was vibrating. I figured the brakes was wet from storms overnight, and after a couple of stops the Brake light came back and the brakes started working well again. Brake fluid res is still full.
TL: DR Brakes are snatchy and pedal is rough when Brake light is off, brakes work fine when Brake light is on, MIL/VSC/TRAC all on.
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 10:04 AM #2
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
scan the car and post the codes, you may need an abs capable code reader
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 05:31 PM #3
Real Name: Tyler
Real Name: Tyler
Autozone code reader is telling me MAF sensor again, so I cleaned it again. However I went ahead and dug in to the brakes and sure enough the left rear wheel bearing seems likes it’s giving up the ship. Inside of the rim, as well as the disc, caliper and dust shield are all coated in a wet grime. I was able to wobble the tire left-right ever so slightly prior to removing it. I went ahead and took the wheel speed sensor off and cleaned it but like everything else back there it was coated in mung. Bearings are beyond my ken, so off to a shop it goes and once they've been replaced (I’ll do both rears) I can replace the rotor and sensor at home since I cannot help but think they are contaminated also.
Can’t complain, 230,000 miles on the OEM wheel bearings isn’t bad.
Old 08-05-2019, 02:55 PM #4
Real Name: Tyler
Real Name: Tyler
Local shop confirmed the bearing and seal failure, as well as the rotor and ABS sensor. Le' sigh, its only money, right?
back , brake , brakes , light , work
Unusual Rear Wiper Blade Problem djpg2000 5th gen T4Rs 6 02-08-2018 04:00 PM
Brake problem and Lock problem Fldivemaster16 3rd gen T4Rs 1 05-14-2013 02:09 PM
Unusual Starting Problem pkinfinity Maintenance/Detailing 7 10-04-2012 09:17 PM
Problem with unusual noise from engine compartment rutledj 3rd gen T4Rs 5 07-23-2012 03:54 PM
BR004-06 03/17/2006 Brakes - Inconsistent/Unusual Brake Pedal Feel CBR_GUY_IA TSB 0 07-12-2009 09:48 PM
