Old 08-04-2019, 07:16 AM #1
TNFISHRMAN TNFISHRMAN is offline
Real Name: Lynn Hobbs
TNFISHRMAN is on a distinguished road
Still having Transfer Case issues
I have tried to get the proper transfer case from a used parts company called LKQ. I have yet to my knowledge received the right one. I have a 2004 4runner SR5 V-8 which is all wheel drive. They have sent me two transfer cases out of two different V-6 donor vehicles. Neither Transfer case will lock into the AWD position the V-8 is standard with. They will switch from High to Low range but the front drive line never will engage. I have checked my front differential and it is in good working order. But the front output shaft of the transfer case will not engage to give me AWD.
I have looked at the Toyota part numbers and there are two different part numbers.The V-8 AWD shows a part# 36100-6D401 The V-6 part number shows a part# 36100-3D510. Does any one know how to tell the difference from the outside of the transfer case which one is which? Also, is there any where I can purchase a rebuild manual and just rebuild my original transfer case that broke? Any help is appreciated.
TNFISHRMAN is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 04:02 PM #2
So nobody had tried to rebuild their transfer case? I assume that there is also no way to tell the part number of the actual transfer case other than what donor vehicle it came from.
Old 08-05-2019, 09:20 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Apparently not, on both counts. The V8 t-case has a center differential that allows AWD, it's internal so not obvious from outside. What happened with your t-case? Why are you needing to rebuild/replace?
Old 08-15-2019, 01:17 PM #4
rdruss, read my other reply where I answered you. I gave the details there.
Old 08-15-2019, 07:23 PM #5
Auditechnician Auditechnician is offline
Auditechnician is on a distinguished road
http://http://car-part.com/mobile/index.htm
Try car-part.com
Will get you the part you need from multiple sources
Auditechnician is offline   Reply With QuoteReply With Quote
awd , case , front , part , transfer
Transfer case replacement issues TNFISHRMAN 4th Gen T4Rs 14 06-07-2019 03:34 PM
Transfer case issues? Try these factory inspection steps Monkey Wrench 4th Gen T4Rs 8 04-02-2017 09:42 PM
1999 Limited 4WD issues (multi-mode transfer case) willhaman21 3rd gen T4Rs 7 12-06-2015 11:47 PM
Who knows about transfer case issues? Bijan 3rd gen T4Rs 1 04-02-2015 09:29 PM
2005 4Runner transfer case issues: rgcary Problems & Warranty Issues 8 05-29-2009 04:45 PM
