08-05-2019, 11:51 PM
V8, should you buy?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
08-06-2019, 12:03 AM
I literally just watched this video. He has a lot of great points about the 4Runner, but staying away from the V8 is one that I really disagree with. The timing belt really isn't a huge issue as long as you service it within the necessary intervals. I personally think that the V8 offers more capability over the V6... More HP, more TQ, high towing capacity and in real world use basically the same gas milage.
If the timing belt is something that holds up anyone from choosing one over the other, they should probably just be looking at buying a Prius.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
08-06-2019, 01:21 PM
Yep a really smart fellow. So glad I listen to him. Not.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
08-06-2019, 02:46 PM
I always trust "mechanics" on youtube. Especially mechanics who are too unskilled to work on complex designs. In this case anyone with a v8 4runner you should stay away from that guy...
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
08-06-2019, 02:51 PM
The timing belt isn't an 'issue' it's a maintenance item at 100k intervals and $800. Woopdeedoo.
08-06-2019, 02:59 PM
3rd gen 4Runners have a timing belt, with all of them approaching 300k miles I'm sure with their complicated engines they are all money pits. LOL.
Some people enjoy their nerfy lives I guess.
08-06-2019, 03:21 PM
Yep Toyota has no history with making great V8's. Everyone should stay with the 4 cylinder and 6 cylinder versions.
YouTube
08-06-2019, 03:27 PM
The V8 is a better platform in every way.
08-06-2019, 03:31 PM
YouTube
Good point, the UZ's are legendary. They've been in tons of lexus cars. The 1UZ is very common for engine swaps, also has a timing belt.
08-06-2019, 03:32 PM
I drive my v8 with two spark plugs removed. So it pretty much a v6 now.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
08-06-2019, 05:15 PM
Oddly enough I'm currently debating the v6 vs. v8, a local dealer has a 2004 v6 SR5 with 150k for $9300 and a 2006 v8 Sport with 121k and the timing belt just replaced for $12900. I commute 60 miles of interstate daily so I'm thinking the v6 but I really dig the look of the 06 Sport model. I sold my 3rd gen 6 months ago and miss it so now I'm shopping 4th gens. Any advice?
08-06-2019, 06:00 PM
Real Name: Skip
Real Name: Skip
Both the V6 and the V8 are great engines, the only thing I will mention is that the early 4th Gen V6s 2003 through early 2006 can have head gasket issues at any time or never depending on the luck of the draw, check the build date on the VIN sticker on the driver's door jamb if the build date is before 12/05 you can possibly have the head gaskets go bad and will need them replaced.
The only other advice I can give is too thoroughly check the frame for rust, if there's any major rust other than minor surface rust walk away, no way to fix that issue short of replacing the entire frame which is cost prohibitive, IMHO, also if either is 4 WD be sure that the system works flawlessly, if the 4WD system hasn't been used regularly the transfer case actuator can freeze/seize up.
2004 Limited V8
08-06-2019, 07:46 PM
Read up on head gasket issues with that V6
08-06-2019, 08:30 PM
The 2008 has standard side airbags. Optional on earlier models. This alone would be the deciding factor.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
08-07-2019, 07:53 AM
Thanks for the advice! I'm going to go drive a couple this week and if I end up getting one I'll let you know.
