Old 08-06-2019, 02:07 AM #1
T4R916 T4R916 is offline
T4R916 is on a distinguished road
Vibration about 65mph
Been having vibration about 65mph. Can feel it in in the gas pedal area. Tires are balanced. Notice tbe vibration in the front seats also. Any ideas on what it can be?
T4R916 is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 02:58 AM #2
ChrisJHarney ChrisJHarney is offline
ChrisJHarney will become famous soon enough
This has been a huge topic of discussion with multiple threads and even a poll taken. If you search it you'll easily find it.
I had the vibration from day 1, even had the dealer look at it before I took delivery. Vibration started at 55 and settled down after 60mph.
Got new tires and had them balanced and an alignment performed. No change.
Swapped out suspension and the vibration started in at 60mph and settled at 65.
Installed second set of suspension pieces, new UCA, had everything aligned, still there.
Installed existing tires on new wheels and the vibration magically stopped. I swore it was the factory wheels being slightly out of round.
Got new tires this year and had another alignment done, and dammit the wobble is back. Not so bad, but back. I have +4 caster and 0 camber. Could be the swap from AT to MT tires, or maybe they aren't as round as my ATs were, who knows.
It's still not as bad as it was with the stock wheels, but annoying none the less.
Some people have it, some people don't. Other than the spindles and LCAs, I've swapped just about everything you can think of in the front, so for what it's worth, I chalk it up to gremlins and try to ignore it.
ChrisJHarney is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 08:18 AM #3
vastano vastano is offline
vastano is on a distinguished road
Just fought this myself. In my case, both front calipers are seized (inside pistons only). This is with the 5th gen upgrade as well...these things lasted ~2 years.
vastano is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 05:08 PM #4
Thanks. I'll check my brake calipers.
Old 08-07-2019, 09:25 PM #5
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
+1 for the calipers...cured my 55-65 vibes.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 09:06 PM #6
j4run j4run is offline
j4run is on a distinguished road
I'll be interested to see if you solve this - please post if you do.
We have a Volvo XC with a similar, high-speed vibration. It's not brakes (pads, rotors, or calipers), link rods, wheel balance, tires, king pins, ball joints, or alignment, but might be axles. It's been present at least 10 years, but not bad enough to replace more expensive parts. Multiple mechanics have multiple suggestions - seems now to be down to simply replacing parts (all of which appear to be OK).
--o-------o-
2008 4R Limited. Mostly stock and runing great!
j4run is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 10:36 AM #7
4v power 4v power is offline
4v power is on a distinguished road
I had Vibration on my gen 3. New steering rack + brushings solved it.
4v power is offline   Reply With QuoteReply With Quote
65mph , ideas , seats , tbe , vibration
Scraping sound above 65mph Davidson 4th Gen T4Rs 5 01-08-2014 04:48 PM
92 4runner rear wobble at 65mph just runnin Classic T4Rs 2 05-16-2011 08:24 PM
Drive 65mph, NOT 70mph!!! thirstyturtle 4th Gen T4Rs 30 02-17-2011 08:41 AM
shaky at 60-65mph Joehert Classic T4Rs 8 01-06-2010 03:21 AM
