Old 11-19-2015, 10:55 PM #1
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
Front differential needle roller bearing replacement
Has anyone replaced their differential needle bearing yet? I see a lot on the tacoma forums but not much for the 4runners. I know they're the same diffs and whatnot but im really looking for a good write up. I know i cannot utilize the ECGS bearing replacement because its not applicable for the AWD models.
I know the part # is 90364-35010, oil seal # is 90311-47012. I really dont want to take my 4runner to the dealer for this change as i'd expect it to be highly labor intensive thus being overly expensive. I know i can do the job after watching the ECGS video on how to. Im just looking for any tips/tricks and if anyone else has done this.
LTDSC is offline   Reply With QuoteReply With Quote
Old 11-19-2015, 11:51 PM #2
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
I have installed the ECGS bushing in two Toyotas so far. Getting the old bearing out is easy as you know from watching the video. Having done it a few times, I'm not sure how easy it would be to pound a new roller bearing back in place. Mine were torn up pretty bad on the way out and I don't think I could use the ECGS process to replace the old bearing with a new one. They aren't very robust.
I'll be curious to see what others post here because I've wondered about this too. I'd be happy to loan you my bearing puller if you want to give it a try.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 11-20-2015, 01:06 AM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Interesting... I just noticed this TSB popped up on TIS recently. Seems like there's a common issue here with these front units at least on the Part-Time 4WD set-up.
T-SB-0026-15 ('04 - '15 Applicable Toyota Models, 4WD Front Differential Groaning Cyclical Noise.pdf
I see though that you're running a V8 unit though...
Well here's the "write-up" straight from the FSM (Isn't that after all the holiest of write-ups? It even has pictures! Take that ancient story book revered and reviled by all!)
File Type: pdf 2UZ-FE 4WD Front Differential Overhaul.pdf (362.4 KB, 1281 views)
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 11-20-2015, 01:11 AM #4
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
Attachment 180741
I have some friends who are service writers and techs. I'll bring this up to them and see what they can finagle. Thank you for this!
Old 11-20-2015, 01:19 AM #5
Well you don't have the part-time front differential so it's not going to be covered under the TSB. That being said, the combination of the pictures in the TSB and the FSM I linked should be pretty helpful in getting the differential apart and put back together.
I'd offer to come to my dealership now that my finger's a bit more healed up, but honestly you might want to save the money if you know some people. Where in NorCal are you again?
Old 11-20-2015, 10:01 AM #6
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
I'm in Vacaville. Im expecting this to be stupid expensive with having to take the diff apart.
Old 11-20-2015, 10:37 AM #7
The TSB has a mini walkthrough in it that doesn't differ in any significant way from the ECGS writeup. That would lead me to believe that you wouldn't have to take the differential apart to do it. According to the TSB, you can tap it in from the driver side tube while it's still attached to the vehicle if you can find the right tool to tap it in place without damaging it.
It does look like they completely removed the spindle, strut, and LCA in the photos on the TSB. That's not completely necessary but the additional clearance would be helpful.
The TSB kind of made me laugh a little. It's the ECGS writeup almost to the tee and they act like it's a newly discovered problem and procedure. This has been a problem on Tacomas for a long while and in Tacoma circles they have done a lot of research to find out what was making the sound. Apparently Toyota's long-standing solution was to replace the entire differential and it was narrowed down to the needle bearing by Tacoma forum members and ECGS.
Old 11-20-2015, 10:38 AM #8
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
Front Differential needle roller bearing replacement
Sadly it's different because I'm AWD. Not part time 4wd. But I'll let the techs decide how they tackle it. I personally don't know the difference in the differential between the two.
Old 11-20-2015, 11:56 AM #9
Sorry. That's what I get for trying to think this early in the morning.
Old 11-20-2015, 04:51 PM #10
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
This ended up being a bad brand new CV axle from NAPA. It was binding on any sort of a load. I have a video ill throw on youtube and post here. Swapped to another new CV axle and it works fine. Crisis averted.
Old 11-20-2015, 04:52 PM #11
Great. What was it doing? I can't stream videos at work and am curious.
Old 11-20-2015, 04:56 PM #12
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
it was violently shaking the differential up and down as it was at idle speed, let alone at a load.
Old 11-20-2015, 05:04 PM #13
Odd. I'll try to watch the video when you post it. I'm curious.
Old 11-20-2015, 11:05 PM #14
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
i hate figuring out how to post videos on each site
http://youtu.be/WzS86C-VkVM
Old 11-20-2015, 11:37 PM #15
Wow. Thanks for sharing.
damaged CV needle bearing retainer krenaud33 3rd gen T4Rs 7 03-17-2015 12:00 PM
4th Gen 2wd front wheel bearing replacement phil123 4th Gen T4Rs 12 12-24-2013 10:10 AM
Front Wheel Bearing Replacement gstai 3rd gen T4Rs 8 11-18-2012 04:34 AM
Front Differential Bearing Help aaroni21 3rd gen T4Rs 1 09-17-2011 09:42 PM
Front Differential Bearing ? pb24 3rd gen T4Rs 10 01-20-2011 06:33 PM
