Old 08-10-2019, 11:45 PM #1
Rstewart's Avatar
Rstewart Rstewart is offline
Rstewart is on a distinguished road
Rstewart's Avatar
What's the trick to removing my CV axles
Pry bar for 30 minutes and rotated to different spots but No luck getting them out of my front diff.
I have it disconnected at the the wheel assy and it's swung out of the way.
Is there a trick to this that I'm missing? I'm probably guessing the problem stems from them being aftermarket CV axles...
06 SR5 4x4 | 33's | OME / Bilstein | SPC UCA's | 4.56 gears with Yukon locker | LED lights inside and out. | Addicted Offroad tube bumper | homemade rear bumper and swing | new skid plate next
Rstewart is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 08:39 AM #2
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
Pry bar will not do it. You need a slide hammer.
radlynx is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 09:48 AM #3
txclimber's Avatar
txclimber txclimber is offline
txclimber is on a distinguished road
txclimber's Avatar
If you don't have a slide hammer you can also knock it out from the back side. There is a small flattened area that you can rest a punch (preferably brass). Hit that sucker with a 4 pound persuader a few times and it will pop right out.
2007 4runner SE V8 4WD: OME BP-51, SPC, Scion IM 2016+
2005 4runner SR5 V8 4WD: ICON Stage 1, Total Chaos UCA, Scion T1819 (SOLD )
1986 4Runner 4WD 22-RE: Full Rebuild, LCE Header, Custom Head, Supra AFM
txclimber is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 11:19 AM #4
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
what replacements are you going with?
rock auto now have cardone axles with hd boots for $65 apiece
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 12:14 PM #5
Mpcuse1 Mpcuse1 is offline
Mpcuse1 is on a distinguished road
Check out this video.
YouTube
Mpcuse1 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 02:58 PM #6
montijo505's Avatar
montijo505's Avatar
If you’re replacing it, grab the wheel side of it and use it like a slide hammer. A few GOOD TUGS will let it come out. There’s a c clip holding it in place that can be a pain in the ass.
Old 08-11-2019, 05:39 PM #7
Rstewart's Avatar
Rstewart's Avatar
That's my plan tomorrow, took a couple day off. It is HOT here in Bama
Old 08-11-2019, 05:43 PM #8
Rstewart's Avatar
Rstewart's Avatar
Not replacing them, just gotta get em outta the front diff so I can remove it.
I stated in another post that I hoped to do a write up on regearing the front, not gonna happen. Found a guy that knows them well, drop the diff, gears, and install kit off to him - $250
Old 08-11-2019, 10:07 PM #9
montijo505's Avatar
montijo505's Avatar
I’ve replaced more CV axles than I care to remember and have always used a pry bar. As long as it’s a big one with a curved end it’ll pop it out no worries. Just have to get between the actual lip of the cv axle and the differential. I can almost guarantee you thought you had it in there but it has a lip that you can’t really see. I’ll take a picture of a spare one I have in the garage in a minute and post it.
EDIT: ok this is what I mean. You were probably prying here, which gives no leverage. These notches can be used to pound on with a flat wide chisel or big flat head screwdriver and a small sledge, but that’s harder due to no room under the truck to swing. What's the trick to removing my CV axles-img_1895-jpg
If you can get the pry bar behind this lip, it’ll pop right out. Just be careful to not poke up in behind that lip too far as you’ll damage the differential oil seal. Use a pry bar that has a curve to it or a large flat head screwdriver and it’s cake.What's the trick to removing my CV axles-img_1896-jpg
Old 08-12-2019, 12:25 PM #10
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Poor man's slide hammer:
Get yourself about 4 feet of 1/8 or 3/16 inch chain, the kind you'd use to put up a swing in your backyard for your kid, plus two carabiners.
Use the first carabiner to make a tight loop with the chain around the fat part of the CV shaft. Use the second carabiner to make a small
loop in the other end of the chain.
Insert your sledge hammer handle through the small loop and take a couple of swings. The CV shaft will pop right out.
Put something soft under the CV shaft to catch it when it falls out.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 12:41 PM #11
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I understand the problem with the prybar. They dont always work because they tend to jam the axle against the bearing at an angle and it won't come out.
This however, works amazing every time and its cheap
https://www.amazon.com/OEMTOOLS-2730.../dp/B01N5SP368
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 11:50 PM #12
GLP's Avatar
GLP GLP is offline
GLP is on a distinguished road
GLP GLP is offline
GLP's Avatar
I used a pickle fork as a wedge and pounded it in and the shaft popped out. For me getting the new one in was the harder part.
-2004 4Runner 4WD Limited V8, Bilstein 5100s, Wheeler's T12 Rear Springs, GY Silent Armor 265/70-17
GLP is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 04:21 PM #13
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
It took a few whacks with a big hammer and a big brass chisel, but it popped right out.
I certainly was nervous hitting that specific component really hard and even more nervous when it didn't move the first few hits. But I read it on the internet so it must be okay!
And eventually the shaft came out.
Keros is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 11:03 PM #14
montijo505's Avatar
montijo505's Avatar
Trick is a BFH every time lol
Old 12-11-2020, 05:11 PM #15
Nitrostangs Nitrostangs is offline
Real Name: Eric
Nitrostangs is on a distinguished road
Real Name: Eric
EDIT: ok this is what I mean. You were probably prying here, which gives no leverage. These notches can be used to pound on with a flat wide chisel or big flat head screwdriver and a small sledge, but that’s harder due to no room under the truck to swing. Attachment 341373
If you can get the pry bar behind this lip, it’ll pop right out. Just be careful to not poke up in behind that lip too far as you’ll damage the differential oil seal. Use a pry bar that has a curve to it or a large flat head screwdriver and it’s cake.Attachment 341374
Ok so whats the trick on getting it back in? Any tips you can give on lining up the splines? I feel like once its seated in the splines it should slide in most of the way until the clip stops it.
I don't know, maybe I'm being to nice with it out of fear of wrecking something.
Nitrostangs is offline   Reply With QuoteReply With Quote
axles , missing , swung , trick , wheel
Tips or trick for removing lower uniball on Icon Coilovers? danthemanx07 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-08-2017 08:59 PM
Does Removing the Lower Grill Insert Require Removing the Bumper? Bluesky 07 4th Gen T4Rs 5 06-03-2016 07:24 AM
Trick for Removing Wheels DaveyBoy 4th Gen T4Rs 19 10-15-2009 12:56 PM
anybody tried this trick? neowig 4th Gen T4Rs 3 08-01-2006 03:10 PM
A little trick Larry Maintenance/Detailing 7 10-25-2003 08:24 AM
