Old 08-12-2019, 01:11 PM #1
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
Exclamation **WATER LEAK** 4Runner Unusual Footwell Water Leak Solution
Introduction
Hello All, I have been losing my mind for almost a year now trying to find a water leak in my 2004 4Runner. It started off on the drivers side where the right foot would usually rest when driving about a year ago and then I noticed the left side was wet last weekend. I have taken it to a dealership, a windshield shop, and a couple of local mechanics and none could figure out this particular leak.
I read all of the forums and checked the typical spots:
  • Sunroof
  • Windshield seal (two holes on each side of glass that can be exposed when new windshield is installed)
  • Grommet in firewall
But to my surprise none of these were the problem.
The past 3 weekends my Dad and I were trying to find this leak. We started running water at the top of the windshield on the drivers side and noticed it would leak in the car. I managed to trace where the water was coming from (or so i thought) and it looked like it was from the rubber grommet. We sealed that grommet so well it will never leak again, but water kept coming in. I gave up and cut the black rubber cover a lot so I could move it out of the way and find the culprit.
We took the Cowell off and I noticed a few cracks on the frame of the car. It wasn't the metal but instead the factory seam sealer.
**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution
It seems to be either a factory defect or just because of the climate we live in, the heating and cooling could've caused it to crack.
We ended up using a screw driver to pry it open, filled it with RTV Black silicone, hammered it back shut, and then put more RTV Black on top of it to ensure it won't leak anymore.
I suggest all of you check this spot on your 4Runner because it looks like it could be a problem for a lot of us in the future.
Last edited by chrisbagnell; 05-22-2021 at 04:05 PM. Reason: Editing to make it easier on the eyes
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 01:46 PM #2
JAXJeremy's Avatar
JAXJeremy JAXJeremy is online now
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
looks like the factory seam sealer cracked.did you have any rust behind there?
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is online now   Reply With QuoteReply With Quote
Old 08-12-2019, 03:31 PM #3
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
im going to check this out on mine and report back - thanks
hinmo24t is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 10:26 AM #4
Real Name: Chris
Real Name: Chris
No rust. I was thinking when Safelite installed the windshield they could've damaged it, but most likely just because of the heat and cold from where i live it took a toll on it. I wonder what other parts of the car the seam sealer cracked
Old 08-26-2019, 04:04 AM #5
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
Holy shit- I hope this is what happened to mine. I took it to the dealer 5 diff times , they said they couldn't figure it out. It would absolutely soak my carpet even though it was just a tiny weep. (rains lot in Oregon)
I removed the dead pedal and peeled the carpet back, ran water over the windshield and I can see a tiny weep of water run down the foot well, but couldn't find the inlet. I too thought it was the grommet.
Summer here and its dry but car smells like mildew and was trying to solve before the rainy season comes back.
Gonna check this tmrw.
Thank you in advance.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 08:22 AM #6
MichonOne MichonOne is offline
MichonOne is on a distinguished road
I just purchased my 06’ SR5 and the 3rd day home I discovered it had a leak somewhere. I immediately go to T4R.org cause I want immediate resolution to my problems. Your solution in my case was the fix for my water leaking issues! Now I did not come across your post first so I was trying things others had tried and I’m surprised that so many people think that the parking break cable that runs behind the pedals is a heater core hose. Your post should be on front page stickies cause it’s definitely the solution. I used Flex seal and adjusted the rubber seal in the wiper cowl that had shifted toward the passenger side and I no longer have the leak. It may be a good idea to seal those spots prior to them leaking imo. I also want to note that mine was nowhere near as bad looking as yours. Mine was like 3 hairline cracks so I was skeptical at first, BUT THIS IS THE SOLUTION!
MichonOne is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 11:01 PM #7
This solved my multi year problem.
Many many thanks.
This ought to be a sticky. !!!
Old 09-03-2021, 10:38 AM #8
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Can I add that this a revelation! It's like finding El Dorado (LOL). I'll be checking mine too...
Admin... sticky this thread?!?!
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:56 AM #9
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Vehicle water leaks are the worst, I had one years ago I just couldn't fix.
Hopefully I never need this info but it's now logged 'upstairs' for future reference!
Thanks OP
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 03:05 PM #10
cnmurray14's Avatar
cnmurray14 cnmurray14 is offline
cnmurray14 is on a distinguished road
cnmurray14's Avatar
OP you're the bomb, this is a life saver.
Sent from my SM-N981U using Tapatalk
cnmurray14 is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 01:59 AM #11
Bethoven's Avatar
Bethoven Bethoven is offline
Bethoven is on a distinguished road
Bethoven's Avatar
We just got one of the biggest rain here in Bay Area and this was a good test for my 07 4runner. Passenger side carpet is all wet. Gotta be the same spot started leaking as I saw few drops in the lower footwell area on plastic covers.
First I didn't understand how the water could get inside. Now I know. Gonna inspect it over the weekend. Kuddos to OP!!
2007 4Runner Limited V6 4x4, Natural White 172K
Bilsteins 5100 all around + OME 884(F) with Icon 52700(R) + Stock UCA. | OEM 18" rims w 275/65/18 Falkens Wildpeak
Bethoven is offline   Reply With QuoteReply With Quote
Old 10-30-2021, 11:28 PM #12
Ujanti Ujanti is offline
Ujanti is on a distinguished road
I just bought an 05 SR5 last weekend and the day after I got it home we had rain for a day and a half. I had the EXACT same issue you are describing. The carpet on the passenger side was soaked, but not higher up near the fire wall. I thought my sunroof drain may be clogged. I tested with weedwhacker line from top and it weirdly jammed, indicating a blockage maybe? After taking off the A pillar trim and passenger kick panel, I fed the line up the drain hose the opposition direction and it seemed to go all the way to the top and jam. Then I concluded the drain tube must be disconnected from the drain in the sunroof underneath the headliner. Took the sun visor and grab handle off so I could pull the headliner down just enough and BINGO!. Water was just dumping into my headliner and following the path down the A pillar to soak the carpet. Not sure if this will be the same for you, but I hope this may help someone!
Side note, no issues after re-connecting the hose. Has rained after twice now and dry as a bone inside!
Ujanti is offline   Reply With QuoteReply With Quote
Old 03-08-2022, 11:58 PM #13
Bethoven's Avatar
Bethoven's Avatar
Fixed my leak. It was just a clogged one side hole in the front. I replaced the rusty sunroof a few months back and probably few pieces of rust got in there and impeded the drainage. So, I cleaned those and its all dry now like a baby's diaper.
grommet , leak , side , water , windshield
SOLVED!!! Water in driver's side floorboard BamaDrewski 3rd gen T4Rs 6 05-21-2020 05:18 PM
Slight water leak.. water pump or??? LargeOrangeFont 4th Gen T4Rs 6 08-26-2019 06:52 AM
SOLVED: Why is water running down my 3rd row seatbelt? 2012sr5 5th gen T4Rs 16 07-28-2019 02:30 PM
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Another Water Leak Fuzzy Fingers 4th Gen T4Rs 2 12-29-2013 07:54 PM
