Old 03-07-2022, 09:06 PM #1
subdued76 subdued76 is offline
subdued76 is on a distinguished road
Back into the game...
I sold my 2007 4Runner V6 a couple years ago, but one popped on Craigslist last night dirt cheap. I ended up buying a 2005 V8 Limited with some curious problems. It has a few codes, but the check engine doesn't light. The check engine light doesn't turn on when the key is switched from off to on or any other time. Are there bulbs that I need to replace or could someone intentionally mod it so the lights don't come on?
subdued76 is offline   Reply With QuoteReply With Quote
Old 03-07-2022, 11:42 PM #2
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I’m going to bet someone tampered with the check engine light bulb to pass it on to an unsuspecting customer. What kind of problems does it have? I would like to pick up a v8 4runner someday.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 03-08-2022, 07:58 AM #3
I was told that it has issues shifting, and that it was in "limp mode". I took it for a drive and seems to be driving just fine. I know the instrument panel was replaced because the carfax mileage went from 220,000 to 144,000 in the last couple of years.
I took it to a auto shop and it had the following codes that I'm looking at cost to fix.
P2433, C1201, P0031
I haven't spent too much time with it because of the weather, but I got a good deal on it so I'm not too worried. I'd be interested to repair the instrument panel if its possible.
Old 03-08-2022, 12:03 PM #4
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
I agree. It's not unheard of - I work with a guy that ran his van out of oil, it still ran (Just) but had fault coldes. He had someone open up the cluster and silicone over all the EMLs and then punted it off to a 'we buy any van' company
Don't worry OP I think you're looking at a tricky but simple problem. Have you tried disconnecting the battery and seeing what codes come back? Is the battery good? Fluctuating voltages can cause all sorts of erroneous fault codes.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 03-08-2022, 01:35 PM #5
mojaverunner9 mojaverunner9 is offline
mojaverunner9 is on a distinguished road
P0031 is a bank 1 sensor 1 o2 sensor. A bosch o2 sensor with the correct pigtail should correct that issue for you. I'm not sure off the top of my head what the other codes are, but that o2 sensor might have caused them.
I just put an o2 in for a P0031 and it solved my problem. Good luck!
2004 SR5 Sport V8 4WD, Doug Thorley Shortys + Gibson Catback
mojaverunner9 is offline   Reply With QuoteReply With Quote
Old 03-08-2022, 02:46 PM #6
That P2433 is for the secondary air injection system, the sensor/circuit is reading high. Could be the sensor, could be a problem with the circuit. Hewitt-tech makes a bypass that may cure it.
The C1201 is a general code. Most likely set by the p2433/p0031. Could also be set due to improper zero point calibration.
P0031 is O2 sensor heater circuit low, most likely a failed O2 sensor but could be a wiring issue as well.
Happy hunting!
Old 03-08-2022, 04:27 PM #7
stopthefury stopthefury is offline
stopthefury is on a distinguished road
Happy hunting!
for the SAIS issues, @slyfox75 is the expert on here.
His system is better and cheaper than HT.
stopthefury is offline   Reply With QuoteReply With Quote
Old 03-08-2022, 11:06 PM #8
Good to know!
check , engine , light , lights , turn
Back in the game NuclearN8 Lexus GX470/460 2 11-28-2018 03:33 PM
Back in the game. sceptre 4th Gen T4Rs 2 07-21-2018 04:23 PM
Back in the game iBison 4th Gen T4Rs 8 04-01-2017 10:28 AM
Getting back int he game Rverrat Cargel New Members 13 12-11-2015 01:22 PM
Back in the game... Nickdsvt 4th Gen T4Rs 6 07-09-2015 11:43 AM
