Old 08-12-2019, 02:20 PM #1
lsmo_guy's Avatar
lsmo_guy lsmo_guy is offline
lsmo_guy is on a distinguished road
lsmo_guy's Avatar
Strange noise
All,
A couple of years ago, I had taken my '06 4Runner to the dealership, and among other things having done, they replaced the brakes. Ever since that time, every time I hit a bump, pot hole, etc, there is a metal clanging sound coming from the front end. Of course, each time I take it somewhere (ie; have tires put on, oil changed, etc) I ask them to see if they can find out where that noise is coming from, and each time they say that they do not see anything, and do not hear a noise. Fortunately, the 4Runner is still driving, no issues, and the noise has not gotten worse.
Has anyone else experienced this? Anyone know what this could be?
I read somewhere that with the older 4Runners, when the brakes are replaced, sometimes the calipers are not seated properly and they can make the clanging noise.
lsmo_guy is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 03:28 PM #2
The Yin's Avatar
The Yin The Yin is offline
The Yin is on a distinguished road
The Yin's Avatar
Brake pads?
I had this issue for years!
Thought it was suspension related, but replaced that and still had it. Checked my calipers and they were torqued to spec. Checked the slash guard underneath and that was set tight.
In the end it was my brake pad. About 3 years ago I replaced my calipers and pads all around. On the front left I install 2 of the little springs to hold the brake pad, and for some reason only 1 on the right side. I think they are only suppose to need one, but it turns out that with out a second one the pads can slide up and down in the caliper just enough to make a "clank" sound when going over bumps.
I tested this out by hitting the same bumps with my foot on and off the brake. I only heard the clank when my foot was off the brakes. Then a few weekends ago, when working on the Runner, I had the wheels off and was able to grab a pad with my fingers, while still in place, and slide it up and down. Sure enough it produce the same clank sound.
I just installed both of these on the front right pads. The guy at Autozone said the one I had was needing replacement, so maybe just one fresh one would be enough, but it seems fine with both, and my left side has had 2 for years.
-The Yin
2005 T4R Sport V6 2wd
The Yin is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 03:36 PM #3
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Does it also happen when you press the brake pedal?
I get the same sound when going over bumps and when i press the brakes.
My pads also have 1 of the springs on each caliper. I thought that it needed 2, but everywhere i looked it only showed one.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 05:29 PM #4
metramm metramm is offline
metramm will become famous soon enough
I have the same metallic clang noise on my driver's side ever since I changed my front pad and rotors with powerstop about a month ago.
I replaced the W clip that came with the new pads with one OEM clip but that didn't correct the issue.
Good to know that I should just need to install another on those pads and the issue should go away!
thanks much!
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 09:08 AM #5
lsmo_guy's Avatar
lsmo_guy's Avatar
Thanks
@The Yin
Thanks for the information, it was really helpful!
Good luck to others as well!
Old 08-15-2019, 11:07 PM #6
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
my left side axle cotter pin rattles over bumps. I bent it a little more once, but not enough. It's more of a ping ping ... ping.
gaber6 is offline   Reply With QuoteReply With Quote
brakes , coming , noise , replaced , time
strange noise clint99 3rd gen T4Rs 5 06-25-2013 08:22 AM
Strange noise grahamcrackaa 3rd gen T4Rs 5 02-15-2012 06:57 PM
strange noise majmattmason 4th Gen T4Rs 3 06-06-2008 05:43 PM
02' with strange A/C noise... RyeBread 4th Gen T4Rs 0 06-26-2007 09:12 AM
4x4 strange noise ljshein Maintenance/Detailing 2 04-25-2005 03:34 PM
