Old 08-13-2019, 10:05 PM #1
gookies gookies is offline
gookies is on a distinguished road
Which way does the transmission plug gasket go?
Just want to confirm, is the "flat" side toward the drain plug while the other side with ridges (crushing side?) toward the transmission pan? Amazon pictures below. Also, is the torque spec 15 ft/lbs?
https://www.amazon.com/Toyota-4runne...gateway&sr=8-4
gookies is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 08:05 AM #2
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 is on a distinguished road
MY GARAGE
Real Name: Newell
MY GARAGE
You are correct. You should be able to see the way the old one sits when you pull it. I believe the Haynes says something in the 15-20lb range. I have done a couple drain/refills re-using the same gasket despite having a new one and just snugging it up by hand. No issues with leaks.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 09:04 AM #3
Yeah, I did a drain and fill and noticed the other day there's a slight leak now, I am thinking I might've placed the gasket the wrong way or just need a new one, also did not over-torque it, just made it snug. Thank you for confirming.
amazon , pictures , plug , side , transmission
Drain Plug no gasket? T4R03 4th Gen T4Rs 3 07-23-2019 06:21 PM
Valve Cover Gasket / Spark Plug Gasket Repacement Jeremy556 5th gen T4Rs 12 04-10-2019 11:03 PM
Drain plug gasket Miranthis 4th Gen T4Rs 16 11-22-2017 10:41 AM
Is '06 V6 oil plug supposed to have a gasket? sbbamafan 4th Gen T4Rs 8 06-04-2007 10:52 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
