Old 08-12-2019, 10:29 PM #1
shahsmerdis shahsmerdis is offline
shahsmerdis is on a distinguished road
front brake line holder rusted off, replacement part number?
Hi there
I finally got to fluid filming my 4th gen, but when i started scraping off the old parts i realized my passenger side brake line hold which holds the two ridged lines rusted off the frame, is there a replacement part i can order to give my mechanic?
i had to grab a pic off the internet
any idea what part number this is? how critical is it that i get it pinned down from vibrations?
Thanks.
front brake line holder rusted off, replacement part number?-rustedpart2-jpg
2004 limited V8
2002 SR5 V6
shahsmerdis is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:54 PM #2
Jdevtac Jdevtac is offline
Jdevtac is on a distinguished road
I went over to parts.toyota website to find the brake line diagram. The diagram is sort of a pile of crap and hard to figure out what’s what but those brackets are pretty easy to pick out. The problem is the bracket is part of the L-fitting, and in all likelihood the associated brake line fittings screwed into that L-fitting will be impossible to salvage so you need to replace the lines or I guess get new fittings and appropriate brake line fab tools. I’ve never done brakes so I really don’t know.
I can post up the part numbers I have and the diagrams I found in the morning if you haven’t found them by then.
I plan on replacing the same parts myself. I think I priced both driver and passenger side lines/fittings all the way to the caliper from the master cylinder at around $150 for OEM. Those brackets in your photos were around $22 a piece if I recall correctly.
Jdevtac is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 04:37 PM #3
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
This is what you need: Toyota P/N 9041210245
Looks like $20 part. It is simply a right angle M10X1.0 inverted flare fitting.
90412-10245 - Genuine Toyota WAY, 2
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 08:43 PM #4
thanks! could you kindly post it or let me know what section it was in? I tried looking for the lines but maybe i was looking in the wrong section im usually pretty good.
2004 limited V8
2002 SR5 V6
Old 08-13-2019, 08:44 PM #5
Thanks man wow only 20 dollars. I was half expecting it to cost more money for nor eason. Looks like the bolt is stuck in the hole though. hopefully its easy to get out.
ill have to bring it to mechanic first to see if he things he can take it apart without it getting ****ed up
what category was this under?
2004 limited V8
2002 SR5 V6
Old 08-13-2019, 09:03 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Power Train/Chassis > Brake Tube & Clamp
2004 Limited V8
brake , number , part , replacement , rusted
Hard brake line part number amajo75 4th Gen T4Rs 1 08-04-2019 09:55 PM
front brake hard line OEM part number or equivalent DK327 3rd gen T4Rs 22 04-29-2019 09:55 PM
Front Brake part chewed and rusted TrexRunnerGirl 3rd gen T4Rs 2 06-16-2018 09:29 PM
Help: part number for brake hard line blackfc3s 4th Gen T4Rs 3 11-12-2017 03:34 PM
Brake line part number Bigmd 3rd gen T4Rs 7 07-14-2017 06:05 AM
