Old 08-14-2019, 01:48 PM #1
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
Stuck calipers - Need to replace the pads and rotors?
So I know(or very strongly believe) my front calipers are freezing. Going with the NAPA reman's this time, OEM pads and will turn my Centric rotors.
My replacement pads won't be here til next week, and have a trip this weekend. Can I replace the just caliper and reuse my current pads/rotors for the week? Then replace the pads, and get the rotors turned?
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 06:43 PM #2
firebirdguy has a spectacular aura about firebirdguy has a spectacular aura about firebirdguy has a spectacular aura about
short answer: yes. if you re-use the pads & keep them matched to the rotors before you turn them they will be fine, especially for a short time.
when you change them, turn the rotors & install new pads & do a proper bedding in procedure.
were the calipers original? how many miles?
Old 08-14-2019, 07:15 PM #3
That's exactly what I was thinking. Any other strangers on the internet??
These are centric brand 5th gen brake calipers. Installed 11/4/17 @ 163,523. I'm at ~192k?? I believe..
Old 08-14-2019, 07:31 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
I would visually inspect the pads first and decide if you want to still use them. Only 1 of the 2 pistons on my caliper was seized, causing the pad to wear at a heavy taper.
I guess if I used it anyways one piston would have just extended more than the other to take up the slack in uneven wear? Not sure if there are any negative concerns with it, but I was not comfortable reusing the old pads in my scenario, but it was also my first time doing brakes so I was perhaps because overly cautions.
Those are just my observations from my own experience.
Old 08-15-2019, 09:24 AM #5
so you only got ~30k miles out of the 5th gen calipers? that stinks.
i agree if the pads are tapered or worn uneven that would be a concern to reuse them, i guess i assumed they were worn evenly. if they are uneven it would probably be best to just do the brake job 1 time & be done with it. if the current pads/calipers still stop ok, maybe just leave it as is for your trip, then do them the right way when youget back. it really depending on the condition of the current pads, if they are in decent shape reuse them.
Old 08-15-2019, 12:23 PM #6
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough
L8Shift's Avatar
I am using the Centri Posi-Quiel Loaded Calipers...
Posi Quiet calipers highlight a Zinc Dichromate finish, or O.E. colored powder coating depending on the application.
Disc Brake Caliper | APC Automotive Technologies
https://www.tirerack.com/brakes/brak...Loaded+Caliper
2006 T4R Limited V8, 150k, Toytec Bilstein, SPC UCAs, StopTech/Centric/Akebono Brakes, Methods/Ridge Grappler 285/70-17, Gibson exh., RCI Skid....
1997 FZJ80 OME 2.5", Kumho AT51s, Slee Step Sliders
2006 Tacoma Pre-Runner Dble Cab Trd#2 Sport
L8Shift is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 12:29 PM #7
L8Shift's Avatar
L8Shift's Avatar
You are probably aware that most brands have different level of products available for most of the vehicles.
Different reman. process are used depending on the line.
Be selective in what you choose...
calipers , pads , replace , rotors , week
5th gen swap, best calipers? Rotors? Oem pads already HIMILESV8SPORT 4th Gen T4Rs 2 04-04-2018 05:43 PM
What are the best rotors, calipers and brake pads davidsg 4th Gen T4Rs 20 02-14-2018 11:06 PM
Calipers, rotors, pads oh my! Jaden78 4th Gen T4Rs 7 12-25-2012 12:17 AM
Replace rotors, pads and calipers on a 4R with 50K miles? Brevard 4runner Maintenance/Detailing 8 09-11-2012 08:53 PM
Pads ... Pads and Rotors ... Pads, Rotors, and Calipers?? lamber74 Maintenance/Detailing 15 07-05-2011 10:26 PM
