Old 08-14-2019, 11:43 PM #1
Buckaroo93 Buckaroo93 is offline
Buckaroo93 is on a distinguished road
Front Spacer Lift with XREAS
Is it possible to install a 2.5" front spacer/leveler with the XREAS system? If so, how?
Buckaroo93 is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 06:34 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
you can add spacers, but i wouldn't recommend it, its much more cost effective to just rip out the tired system and go fresh shocks and springs, for me spacers are a band aid, you still need to pay for alignment after doing the work. why invest in a tired system? i like to tell folks who do the same with stereos, why try to add subs or mids and highs to the factory radio and not do it right with aftermarket radio that has why more features and better end results.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 08:59 PM #3
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
^this. XREAS is garbage, XREAS with spacers is more garbagey. If you’re on a budget throw some bilstein shocks & springs all around. If you have a little bit more go with eibach. Save your pennies.
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 03:08 AM #4
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
I bought a 2006 v6 4x4 4runner with 192k that had the xreas and a 3" lift front and 2" lift rear. I can tell you that it was horrible. The car was unstable and was dangerous to drive. The xreas suspension was done.
What i did was install 2018 4runner struts and shocks with the spacer lift and that lasted me about 5k. Because of the spacer lift, the rear shocks wore out really quickly.
So now i am ordering bilstien 5100 shocks with Old man emu 885 springs to repair it. Just do it right the first time.
pahaf91 is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 12:51 PM #5
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
To counter the above statements, I put a 2.5" Daystar spacer lift on my '06 Sport three years and 50,000 miles ago, and it's been just fine. The XREAS is still healthy and rides well, so I see no reason to pull it out until it fails. When it does, I'll probably install Bilstein shocks all the way around.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 04:17 PM #6
grave's Avatar
grave's Avatar
A likely story..
pet every dog
Old 08-16-2019, 04:24 PM #7
Real Name: Ron
Real Name: Ron
Originally Posted by grave View Post
A likely story..
That's a totally uninformed statement. I'm there, you're not. I don't see how you'd know more about it than I do.
Old 08-16-2019, 07:28 PM #8
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
I really need to chime in with some real experience, not opinions.
OP wants advice on spacers and xreas, not what he should do. His xreas might still be ok.
spacers roughly 150.00, labor- few hours.
4 bilsteins 400.00, 4 springs roughly 600.00 new, upper mounts 100.00, labor 3-500.00. Total roughly 1600.00. Big difference.
I had my spacers on my '06 for 5 years before the xreas crapped out, absolutely no issues during that timeframe. Now replaced with bilsteins. The same spacers are now on my '08 with xreas and still no issues and ride exactly the same without them.
If there is nothing wrong with your xreas system then spacers will be just fine.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 04:02 AM #9
cairn cairn is offline
cairn is on a distinguished road
mine's at 190k with original xreas. drives great, but i'm saving for the inevitable replacement. thanks for making it real for me - gonna have to save a little more than i thought!
cairn is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 11:18 AM #10
Jason B's Avatar
Jason B Jason B is offline
Official Vendor
Jason B is just really nice Jason B is just really nice Jason B is just really nice Jason B is just really nice
Official Vendor
Jason B's Avatar
I can make you a custom kit in any size you want, we first designed these kits off an Xreas 4Runner to begin with so I know alot about what works etc, BUT, with Xreas you can't do too much front without doing a rear spacer also, or the system will try to compensate. A 2/1 and 3/2 etc is no issue. I tell most people to measure the spacing on all for fenders and then can make you a kit for exactly how you want the truck to sit. Some rake, no rake, etc, etc.
4th gen lift and leveling kits at Burtman Industries
Also, go here to see many installed pics from customers with these kits:
Lift & Leveling kit Holiday Season Sale!
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
[email protected]
DO NOT PM - text/call 717-319-2100 (24/7)
Jason B is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 07:30 PM #11
Here's the deal. The RAS crapped out not long ago. Had a mechanic look at it and he replaced the RAS with coils. NOW I'm sitting 22.5" in the rear from center of hub to lip edge but 18.5" front. Don't need a lift in the rear but 3" in the front. (I don't mind a little rake) I have some spacers but when I got to reading, I read it can't be done, it can be done, it's best not to do it........so my question is......
CAN THE FRONT SHOCKS BE DISCONNECTED FROM XREAS WITHOUT HARM TO THE SYSTEM? IF SO, HOW DO I GO ABOUT DOING IT?
Old 08-18-2019, 10:48 PM #12
RobD RobD is offline
RobD will become famous soon enough RobD will become famous soon enough
Also, maybe not start more than one thread on the same topic.
RobD is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 08:52 AM #13
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
You can't, the front and rear shocks are connected so it's either all or nothing.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 07:55 PM #14
Flybynight's Avatar
Flybynight Flybynight is offline
Flybynight is on a distinguished road
Flybynight's Avatar
06 limited, can I go 2" spacer up front? I have to level it out. Suspension is fine, 149k.
Also I don't get the XREAS hate, I've driven all the new 4runners and only the limited I liked. All others rode like 90's body on frame 4x4's, which is why I bought one lol
Flybynight is offline   Reply With QuoteReply With Quote
front , install , spacer/leveler , system , xreas
Max Safe Spacer Lift with XREAS? DannyBoy13 5th gen T4Rs 10 12-11-2013 01:40 PM
Shop said can't do my XREAS spacer lift coreyray7 4th Gen T4Rs 17 06-27-2013 12:58 PM
FS: Daystar 2.5 Spacer lift (for xreas) GYoter For Sale: Suspension/Wheels/Tires 2 01-16-2012 07:38 PM
WTB Spacer lift for 05 with xreas. czastrow Want to Buy/Trade 0 09-03-2011 09:30 PM
**SOLD** toytec 2.5'' spacer front lift and rear 1.5" spacer lift 4Runner8 Classifieds - buy & sell (no commercial ads please) 1 08-10-2010 06:06 PM
