01-04-2021, 02:22 PM
#91
Registered User
Real Name: Morris
Registered User
Real Name: Morris
You guys should make/sell some Sherpa Motorsports #4628 Race shirt so we can show support.
01-05-2021, 11:23 AM
#92
official vendor
official vendor
We definitely need to. It's hard to find time to work on the race car right now let alone sell shirts on the side but I'm sure we can make it happen soon enough.
01-10-2021, 12:49 PM
#93
Random but, how did you mount that light bar in the spoiler? Looks clean there versus some other mounting locations I keep seeing.
01-11-2021, 07:50 PM
#94
official vendor
official vendor
We simply just cut out the area on the back to allow the lights to pass through, drill holes on the bottom, and bolted it in with some washers to keep the plastic from cracking. Holds up great so far.
01-11-2021, 08:04 PM
#95
official vendor
official vendor
Over the weekend we did some really boring stuff and got started on some really cool stuff!
The boring stuff was ripping the old axle out and cutting all the old brackets off the frame. We also rebuilt our front cross-member that was destroyed, tied it into the cross-member the a-arms mount to as well as got the Addicted Offroad bumper cross-member to our frame as well as the engine cage landing on the bumper.
On to the fun stuff, we designed, cut, and welded our 4 link brackets for the new 4 link. I have lots more pictures coming as well.
Here is a sneak peak.
01-12-2021, 11:57 AM
#96
official vendor
official vendor
We started to land links last night. We got our upper and lower mounts tacked to the housing, as well as made our lower links. We also got one of our lower mounts tacked on. It was late and a jack stand was blocking the other side so that will go on tomorrow, we are also going to cut and bend our upper links.
For the links we are using Summit Machine Billet Joints, these things are beefy. One side has a threaded bung so we have adjustability, the other end will be fixed and is welded to the link. As far as the link itself it is made of 2" 1/4" wall DOM and the uppers will be 1.75".120 Wall DOM. This should provide us with plenty of strength and longevity with these. The lowers are BEEFY. The upper will also be very beefy when compared to the factory links.
And boy is it wide!!!
As far as the housing goes, we are running a Trail Gear 9" Housing. This is their Full Float Roller Kit so it comes with nearly everything you need to have a roller housing. The housing, the weld in bearing pockets, Dana 60 Hubs, brake calipers with mounts, rotor, and lugs. We then had to buy the Dana 60 hub drive flange kit, a Truss, and the axle shafts which are equal length 35 Spline Chromoly shafts.
We have the 3rd member being built right now along with the front and we will update you on that shortly.
01-12-2021, 12:20 PM
#97
Nice build. Looks like you've been getting some good seat time over the last year.
Your gonna love the ROCKS of JV!!! they big. Looking forward to seeing your build prep for KOH and all the fun you have in the race. Good Luck, keep it rollin.
Couple Yotas
Iluv4xToys!
01-13-2021, 12:28 PM
#98
official vendor
official vendor
For those curious, here are the 4Link numbers we landed as close as possible to.
Also, something from Locked Offroad showed up this morning for the front...
01-13-2021, 12:52 PM
#99
Real Name: Brett
Real Name: Brett
Ironically I was trying to learn about Anti-Squat last night and this morning. It looks like you did a pretty good compromise between desert and crawl percentage for the rear axle.
I'm gonna try to stuff some 14" bypasses under mine, but I plan on getting my butt kicked in the beginning, trying to learn the geometry of it all.
Took me an hour to find free software to be able to write into the calculator, finally settling on Apache. It's the one I use the most everyday anyway, I was over thinking it for awhile. Just had to figure out what format I needed. Paying for Microsoft WAS NOT an option what so ever.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
01-13-2021, 08:26 PM
#100
official vendor
official vendor
Its been a huge learning curve for us too. I'm sure we ended up a little off from the calculator but as long as its close I am happy. We wanted to split the difference as this car will certainly shine in the desert much more than the rocks but we will try to make it good at both! Driver mod will be required for sure.
01-15-2021, 02:13 PM
#101
Looking forward to KOH and seeing your truck in person.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
01-16-2021, 09:15 PM
#102
This thing looks amazing
01-18-2021, 03:06 PM
#103
official vendor
official vendor
01-18-2021, 03:16 PM
#104
official vendor
official vendor
The 200 series rack is getting ready to go in as well. We started by removing the factory bushing to have our offset spacers machined. The hole spacing needs to change about 1/2" to fit the 4runner frame.
So, that is off having the parts made, should have them back sometime today actually.
Stocked up on a bunch of fluids for the truck.
Got the roof rack ready to rock as well. We gotta do some marketing so threw some Maxtrax on the rack (which may come in handy) and a rotopax for show.
Replaced our final original bump stop mount.
Painted these.
Installed our Yukon Air Compressor
And here is where she sits. Front end comes Wednesday... hopefully.
There is a lot of other small things we have done that I don't have pictures off such as more cage reinforcements, wiring, took all the decals off to prep for a wrap, and a whole lot more.
01-18-2021, 03:20 PM
#105
Registered User
Real Name: Morris
Registered User
Real Name: Morris
That is some amazing work! Can't wait to see it in action!
