Old 01-18-2021, 04:06 PM #106
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Forget bulletproof, that rear axle is bomb-proof.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 01:01 PM #107
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
Another very important piece to the 200 Series Land Cruiser rack swap.
Black Peak Engineering whipped up these new bushing replacements "Solid Spacers" for our steering rack to bolt into the factory location on the 4runner.
These are made to the exact spec of the factory bushings but offset to line up with the 4runner frame, they are press fit and made out of 7075 Aluminum. Thank you, CNC Mills.
Industry Leading Modular Storage Systems that allow you to Adventure with Confidence.
Our WebsiteOur InstagramOur Facebook
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 01:30 PM #108
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
amazing build and progress. Can't wait to see this complete. It's going to be one hell of a t4r..
aemravan is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 02:04 PM #109
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I'm sure you guys are busy but could you elaborate a little more on the 200 series front rack and pinion?
Other than the offset spacer aluminum bushings and maybe some minor plumbing, did you have to do any other custom stuff to fit it?
Inner and Outer TRE's mate up fine?
Do you think the solid aluminum spacers will cause the rack to wear faster? Or?
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 04:27 PM #110
official vendor
official vendor
It's a bit of trial and error over here. So far it looks like everything is just going to work as far as plumbing goes. As far as the tie rods we are using the inners but making the outers out of DOM tubing and a hiem joint on the spindle side. So using a but welded on the inner side and a jam nut to allow adjustment just like factory but way stronger. On the spindle, we are doing a double sheer mount.
The solid mounts will definitely be harder on the components.
Old 01-25-2021, 07:55 PM #111
official vendor
official vendor
Tonight is the last night before the 4runner is loaded up and headed out to California to get wrapped, fiberglass installed and buttoning up a few loose ends.
Here is what we have finished.
First, the front suspension, steering, front diff, and everything that goes along with that.
The arms are from Total Chaos, it is their +3.5 kit. We ended up having to run the 8" Coilover again as we couldn't really get the 10" to work without need a coil compressor to install and uninstall and we did not want to deal with that on the lake bed if we had to pull it out for some reason. The 8" will still work amazing but hope to get the 10" to work with maybe a shorter shaft down the road.
We made our double sheer steering and hiem setup, this was hard as the misalignments we got were not right and we had to get creative to get our travel back without binding the hiem. This isn't ideal yet and definitely stole some down travel from us. Still way stronger and will work. Also, drilling out spindles suuuuuuucks. We upsized to a 3/4" bolt which was awful. We may end up sleeving this and running a smaller bolt to get more misalignment in the future.
The front diff, steering rack and oil pan are all really tightly packed now. It's extremely tight with the 200 series rack in there but it works.
We also swapped the studs on the front to match the rear axle.
Here it all is together.
Its wide...
But, all the wiring is finished, diffs are in, the rear axle is done, custom brake lines are all done (that was a big project), new window nets, new limit straps front and rear, intake is in, new radiator and hoses, fluids changed and a good bit more of random things.
We have a decent list of things to knock out tonight then it's off to Beyond Wraps for some tasty vinyl goodness.
Old 01-25-2021, 07:57 PM #112
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Badass work guys!!
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 01:35 PM #113
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Sherpa!! #4628
Ultra4 4628 Race car - Sherpa Motorsports-20210205_123001-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 02:16 PM #114
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Watching in between work, spicy unit spotted
Sent from my Pixel 2 XL using Tapatalk
y=mx+b is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 05:15 PM #115
Real Name: Brett
Real Name: Brett
Still racing
Ultra4 4628 Race car - Sherpa Motorsports-screenshot_2021-02-05-live-2021-4wp-every-man-challenge-live-video-tracking-updates-png
Old 02-05-2021, 09:53 PM #116
Broke_Runner's Avatar
Broke_Runner Broke_Runner is offline
Broke_Runner is on a distinguished road
I’m really hoping there’s a good write up on that 200 series rack install I’m wildly interested in it
Broke_Runner is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 10:27 PM #117
What is everyone watching this on tomorrow ??
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
Old 02-06-2021, 12:16 AM #118
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
how'd they do? anyone know?
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 02-06-2021, 03:47 AM #119
Real Name: Brett
Real Name: Brett
J.
I think they ran out of time. They were stuck in the rocks with about 4 or 5 other cars that hadn't moved for close to an hour.
Last I saw was 12th in class.
Edit: Only 2 finishers in the stock class. By all accounts, even the desert section was brutal this year.
Old 02-11-2021, 11:16 AM #120
official vendor
official vendor
Thanks for following along with the race and our progress! We have a full race recap and photos coming soon!
We did not finish, but I would count what we accomplished as a great success and puts us in a good position for the rest of the season and next year!
build , email , motorsports , sherpa , ultra4
Sherpa Equipment Company - 4th Gen SherpaEquipmentCo 4th Gen T4Rs 68 12-02-2023 12:24 PM
Sherpa Equipment Company - 5th Gen SherpaEquipmentCo 5th gen T4Rs 393 11-12-2023 01:57 PM
SRQ Fabrications Ultra4 4600 3rd Gen Build SRQ-Runner 3rd gen T4Rs 184 04-13-2020 04:57 PM
2019 Mint 400 Offroad Race Sponsor SALE: METHOD Race Wheels - Come Party with Method! Battle Born Offroad Off Topic 2 03-11-2019 08:29 PM
4th Gen 4Runner v8 IFS Ultra4 Build - Opinions Needed Charles4x4 4th Gen T4Rs 39 06-19-2018 01:36 PM
