Old 08-15-2019, 10:06 PM #1
Buckaroo93 Buckaroo93 is offline
Buckaroo93 is on a distinguished road
Strut Mount/Top Hat With Spacer
Using 2.5" front spacers for leveling. The spacers I have use the typical set-up where it is mounted to the strut using the top hats' 3 top bolts. THEN there are 3 threaded holes between each of the 3 top bolts. This is where the supplied bolts run through the mounting "surround" into the spacer. The question is this...
Can I rotate the strut mount 90 deg leaving the rubber isolator where it is in order to line up the new holes? Any foreseeable issues with that?
Buckaroo93 is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 02:26 AM #2
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
not sure if im understanding the question correctly. you bolted the spacers onto the strut but the spacer doesnt have studs coming out. Only has holes for the bolts? if so, you have some weird spacers. Most of them come with studs coming out on top.
what i had to do was install the spacer on the strut and then "flip" the strut around so the holes would line up. I tried to turn the top hat to line up with the strut studs but it was impossible to do. They were firm in place
pahaf91 is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 10:34 AM #3
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
If you can and should be able too. Mount it on top like your asking, push the LCA down and turn the lower eye hole to be able to bolt up to the LCA.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
bolts , holes , spacer , strut , top
KYB strut mount kit MtlT4R 5th gen T4Rs 12 04-01-2020 03:54 PM
Spacer/5100s/Or complete strut? Jeremy107 4th Gen T4Rs 16 10-10-2018 05:30 PM
Strut Mount keep old or get new ones? mrwinkle13 4th Gen T4Rs 2 09-26-2015 08:06 PM
FJC shock/strut and spacer question NorCalKevin Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-24-2011 04:56 AM
