Old 09-20-2019, 05:53 PM #16
philipalberti_'s Avatar
philipalberti_ philipalberti_ is offline
philipalberti_ is on a distinguished road
Originally Posted by MDPensFan View Post
Hey Phillip, sweet build! How do you like the AKKON headlights? Any condensation or fitment issues? Adequate light beam from them?
I saw them on Amazon and was pondering those as a replacement for my OEM assemblies with cracks all over them.
sorry for the late reply. But thanks! i like them a lot. for 100 bucks shipped they’re great. no condensation yet. but it doesn’t really rain here in SD. as for light beam it’s pretty much the same as oem. i got cheap $10 LEDs off amazon so it made them way brighter too
05 limited 4runner 4x4 Philip Alberti's 05 4Runner Build
philipalberti_ is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 05:54 PM #17
Originally Posted by montijo505 View Post
Looks great. I have a thing for white 4Runners though!
thanks man. my whole fam is all about white toyota’s haha
Old 09-20-2019, 05:56 PM #18
Originally Posted by FrontRange4 View Post
When you switched from the Spec D headlights to the Akkon headlights did you have to buy new bulbs? I want to buy the headlights you have but it seems like I would need to use the stock bulbs and I don't want to pay the $300 for a nice pair of LED lights to put in the headlights. The nice thing about the Spec D headlights is that it seems like they come with the LED light built into the headlight assembly.
i bought them brand new in box off a person on offer up. they came ready to install so no need for bulbs unless you want to replace them for whatever reason. oem bulbs don’t fit so you’ll need to get h11 bulbs i think.
Old 09-20-2019, 05:58 PM #19
Originally Posted by hinmo24t View Post
so badass on the trail access out there, behind your HS. the one pic where the jeep is about to climb looks really fun.
thanks! and yeah it’s real convenient for a quick run.
Old 09-21-2019, 06:17 PM #20
Couple new posts coming soon. I recently trimmed the front fender flares 2 inches higher all around for more clearance, and because I ripped one off booking it over the whoops at Pismo Dunes haha.
Also just did a flowmaster 40 series exhaust a couple weeks ago. Cut off the old muffler, welded on the 40 series and dumped it before the axle. Way more aggressive and makes the V8 sound better.
Old 09-23-2019, 10:51 PM #21
slixx1320 slixx1320 is offline
slixx1320 is on a distinguished road
Loving the runner! Did you have to perform BCM with the tire/lift combo?
Regarding the headlights, it will look and perform so much better if you get the retrofit. I have it on mine and I refuse to ever go back to stock.
slixx1320 is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 02:12 PM #22
Thanks dude! and yeah, after I put the 1.25 spacer up front I had to chop the body mount. It rubbed like hell at any turn. It wasn't that bad before the spacers tho. Took maybe an hour with prep to cut it with a cutting wheel/grinder.
Eventually I'd like to do the same or put a BD squadron in my high beams. I've seen it a couple times on Instagram.
Old 09-30-2019, 02:22 PM #23
I'll get to the flowmaster install pics someday lol, but went out to Pine Valley this past weekend. Super fun with all the mud. Here's some pics. Might be able to notice the fender flare trim in the front. Also plasti dipped my fronts gold just for fun.
Philip Alberti's 05 4runner build-img_1434-jpg  Philip Alberti's 05 4runner build-img_1442-jpg  Philip Alberti's 05 4runner build-img_1454-jpg  Philip Alberti's 05 4runner build-img_1471-jpg
Old 09-30-2019, 02:56 PM #24
montijo505's Avatar
montijo505's Avatar
Looks like fun!
Old 09-30-2019, 03:10 PM #25
Here's a link to the steps I took to trim the front fenders. I definitely regret not taking pictures along the way but I just followed the original thread. linked that thread too. 4th gen front fender flare trim
Old 09-30-2019, 03:13 PM #26
Looks like fun!
yeeeaaah. Gotta love splashing around and getting dirty. Also the weather was great. 55-60 degrees is way better than the heat SD has been getting.
Old 09-30-2019, 08:28 PM #27
40 series install
So instead of paying 400 bucks for a borla or 700 for a magnaflow catback system, I decided to pick up a flowmaster 40 series from amazon with a turn down tip. I ended up getting 2.5 inch outside diameter pipe and a 2.25 to 2.5 diameter conversion pipe, as the original pipe is 2.25 inch outside diameter.
To remove the old rusted exhaust, I snapped the bolts connecting the y pipe to the muffler pipe, took off the hangers and used a sawzaw to cut the pipe that bends around the axle off from the muffler for easier removal. Drilled out the old bolts and later used a new pair of bolt/washers/nuts.
To keep the existing flange and hanger, I cut off the old muffler from the pipe. Using a 2.25 to 2.5 adapter, I connected the the original pipe to the 2.5 pipe then to the flowmaster. To connect the turn down tip, I cut about 6 inches of 2.5 pipe so it would slip into the flowmaster and the tip.
All connecting pieces were welded using my cousin's Lincoln mig welder. It was my first time welding, so it's not the best. However, no leaks and some black spray paint cleaned it up real good haha.
New issue was finding a way to make the exhaust sturdy as the only usable hanger was right by the flange. The exhaust didn't have a lot of play, but just to make sure, I wrapped exhaust wire, or whatever it's called, around the flowmaster and to the frame. No play and no banging against anything so it held up great so far.
Here's what I bought off of amazon and what it all looks like. It wont let me upload the video of it, so here's some crappy screenshots for now.
Total price was roughly 100 bucks. I guess the price on the exhaust tip changed because I know I spent around 10-15
Philip Alberti's 05 4runner build-img_0147-jpg  Philip Alberti's 05 4runner build-img_0148-jpg  Philip Alberti's 05 4runner build-img_0150-jpg  Philip Alberti's 05 4runner build-img_0149-jpg
Old 10-01-2019, 02:42 PM #28
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
I had a 40 series on my 3rd gen - it was a solid setup. Loud, and definitely had drone at certain rpms, but sounded great. Bet yours sounds nicer with the V8!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 12:12 PM #29
yeah it definitely drones a lot around 60. but it’s well worth opening up the V8
Old 10-03-2019, 12:47 PM #30
TheUltimateBohab TheUltimateBohab is offline
Real Name: Craig! Craig Christ!!
TheUltimateBohab is on a distinguished road
Man I love those rims in the third post I think I want to get black for mine too!
What did you end up doing with those old Springs? The red ones I just bought mine today actually black but I got all red bushings coming to so the Red Springs would really make it pop... those tires rub at all? I was looking for the biggest I could get that wouldn't rub but I'm only going up 3 in....
TheUltimateBohab is offline   Reply With QuoteReply With Quote
amazon , coilovers , front , lights , spacer
05 4runner SR5 V6 4x4 Build keitht253 4th Gen T4Rs 59 11-12-2018 12:40 AM
Just another 4Runner build NcYota99 3rd gen T4Rs 15 03-18-2015 08:49 PM
Fj to 4runner build! hotsteel41 5th gen T4Rs 8 08-27-2014 03:21 AM
4Runner Kid's Build #2 4runner_kid Classic T4Rs 17 12-19-2012 02:24 AM
88 4runner build SV_Dude Classic T4Rs 21 03-15-2010 09:40 PM
