Old 08-18-2019, 11:34 AM #1
SHagood's Avatar
SHagood SHagood is offline
SHagood is just really nice SHagood is just really nice SHagood is just really nice SHagood is just really nice
SHagood's Avatar
4th Gen Actuator, Help!
Read several forums on here and my issue has been narrowed down to the actuator motor behind the glove box. My AC only blows cold air and of all the settings, only blows air out of the head-level fan. Defrost, feet, feet/head, feet/defrost, it still only blows out of the head-level.
Took apart the glove box, and located the vibration/buzzing noise coming from the actuator (which is in an incredibly inconvenient location). I wrote the part number down, but can't seem to find a place to buy that specific part, any help is appreciated!
Denso
063800-0660
12V 3K 5270 AUTO
2008 Urban Runner
MY BUILD THREAD
SHagood is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 11:49 AM #2
montijo505's Avatar
montijo505's Avatar
Rockauto.com has a different brand, not sure if you’re set on Denso for the replacement.Attachment 1
4th Gen Actuator, Help!-img_1923-jpg
Old 08-18-2019, 12:58 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Here's the Toyota part numbers (different than the Denso part numbers) for all the servos, you can find them for less at other sources and or eBay, approx. around $100
You maybe able to find them used from a savage yard and save much much more, or go with an aftermarket part.
Blower Motor & Fan for 2008 Toyota 4Runner | Toyota Parts
2004 Limited V8
Old 08-18-2019, 03:32 PM #4
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Just replaced both of mine with Ebay items - total of about $200. They work great. Read all the threads on how to replace them, because there is a trick to getting to two of the screws that are terrible. I did both of mine in about 90 minutes.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 07:53 PM #5
SHagood's Avatar
SHagood's Avatar
Thank you sir, I appreciate it! Not dead set on Denso, just heard to keep the Japanese parts for Toyotas but I'm open for anything at this point.
2008 Urban Runner
MY BUILD THREAD
Old 08-18-2019, 07:53 PM #6
SHagood's Avatar
SHagood's Avatar
Thanks man!!
2008 Urban Runner
MY BUILD THREAD
Old 08-18-2019, 07:55 PM #7
SHagood's Avatar
SHagood's Avatar
Any tips or tricks? I took apart the glove box and removed the HVAC motor. I can't seem to find an easy way to locate the mount and remove the screws, think I counted 4-5 in total but are a pain to access.
2008 Urban Runner
MY BUILD THREAD
Old 08-18-2019, 09:35 PM #8
08TxRunner's Avatar
08TxRunner's Avatar
Follow this excellent write up. DIY: Replace Servo Sub-Assy - Toyota 4Runner Forum - Largest 4Runner Forum
And open the recirc door to the up position, drill a hole in the casing from the inside towards those bastard screws. Use a screwdriver through the hole to remove/replace those screws. Gorilla tape to seal the hole.
Old 08-18-2019, 10:42 PM #9
SHagood's Avatar
SHagood's Avatar
Dang that thread is legit! Thank you sir.
2008 Urban Runner
MY BUILD THREAD
Old 08-19-2019, 09:15 AM #10
08TxRunner's Avatar
08TxRunner's Avatar
Drilling that hole is key. If you think about it, for both servos you're only removing/replacing 8 screws. If not for the cramped location it's a 5 minute job. It's the lack of access to several of those screws, and if you read through the various threads, there are guys who spend hours dealing with them. As suggested by someone on here, drill that hole and the job will be a cake walk. If I were to do it again, I have no doubt it could be done in less than an hour for both servos.
Old 08-19-2019, 01:33 PM #11
SHagood's Avatar
SHagood's Avatar
Awesome, thanks bro!
2008 Urban Runner
MY BUILD THREAD
Old 01-22-2020, 11:08 AM #12
lcattin lcattin is offline
Real Name: Les
lcattin is on a distinguished road
Real Name: Les
Thank you all for this information.
I have been working taking things apart for 3 days trying to get that servo out.
Was trying the blower box removal but couldn't get that one hook to release to allow the box to come out so I got frustrated and drilled a hole. Then had to drive to town to buy a screw driver long enough to reach that screw.
When my part arrives now I have to stand on my head again to get that screw back in. I'm getting too old for this....
1998 4Runner Limited 2wd 3.4L
lcattin is offline   Reply With QuoteReply With Quote
actuator , air , blows , box , head-level
Door Actuator or Fob Issue? (One Actuator Already Replaced) Mlynn 4th Gen T4Rs 6 06-28-2022 12:02 PM
ABS actuator removal thardy 3rd gen T4Rs 6 10-30-2017 05:22 PM
Actuator Replacement nvestor88 4th Gen T4Rs 11 07-24-2014 11:47 PM
Can't ind actuator lonewolf98765 Classic T4Rs 15 12-09-2013 09:30 AM
4Lo actuator faqoldschool 4th Gen T4Rs 6 09-23-2012 12:12 AM
