Old 06-10-2019, 08:00 PM #1
Dry-fly's Avatar
Dry-fly Dry-fly is offline
Dry-fly is on a distinguished road
Dry-fly's Avatar
Need some advise for my 2007 4Runners LCA bushings and PS rack
So we’re going on a long road trip in about a month and I have my 4Runner at a local Toyota only repair place I trust a lot getting a look over. I just got a quick phone call saying my steering rack is leaking badly and the lower control arm bushing are shot. Now, before y’all say do it yourself.... know that I would, but I have had two spinal fusions and cant anymore. I use to be into off roading a lot as well as doing my own mods, alas some of those days are gone....
Anyway, my mechanic is getting back to me in the AM with estimates but I thought I’d hit y’all up with a couple of questions. Is there any other preventative stuff that should be done while in there? Won’t he be in the vicinity of the control arms anyway doing the steering rack? Any idea what this is going to come back costing? I’m in the DFW of Texas. Thanks for the help guys! BTW, my 4Runner is a 2007 V8, 4x4 Limited with 184k on it.
Dry-fly is offline   Reply With QuoteReply With Quote
Old 06-10-2019, 08:04 PM #2
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
You may want to do fresh wheel bearings if they’ve never been done.
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 09:52 AM #3
timbo_slice's Avatar
timbo_slice timbo_slice is offline
timbo_slice is on a distinguished road
If your car has seen a lot of water Dznuts has a good point...
I would say check the lower ball joints if he is taking the lower control arm off that is the main contact point so he is halfway there. Check your CV's make sure the boots are in good shape and are not torn if you are 4x4.
2008 T4R - SR5 - V6 - Bilstien 5100 3rd clip - Toytech #620 front springs - Total Chaos UCA's - Toytech Superflex rear springs - 275/70/17 (32") BFG KO2 on stock 17" rims - Pioneer deck w/ bluetooth - All synthetic fluid
timbo_slice is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 12:27 PM #4
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
Be prepared for an expensive quote....
In total for a steering rack and replacing LCA bushings Id say the quote will be over 2 grand.
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 07:20 PM #5
Cloud9's Avatar
Cloud9 Cloud9 is offline
Cloud9 is on a distinguished road
Cloud9's Avatar
Find a good independent shop. I'd do it for you if you drive here.
2019 TRD pro - S&B intake, Gibson Side Dual Catback black ceramic tips, Sprint Booster. lift coming
2006 4Runner V8 - Doug Thorley Headers/Hi-flow Magnaflow Cats, Gibson Catback Dual Exahust, Volant Air Intake, Sprint Booster, All from Burtman Industries
1996 Limited 3RD Gen, still going strong!
Cloud9 is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 02:11 AM #6
Acw137 Acw137 is offline
Acw137 is on a distinguished road
What did it cost?
I have a similar issue with my 2001 T4R (150k) and would like to know what you paid. My mechanic says an end seal on my power steering rack is leaking, the rack needs replacing, and he says that to do this, the control arms will probably need replacing too, because of something to do with the control arm bushing being seized up in T4Rs as old as ours. I’m not a mechanic! Does his advice make sense and sound reasonable? He’s quoting over $2k.
Acw137 is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 01:43 PM #7
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
With parts absolutely.
My advice, do it yourself. You can't though. So definitely negotiate a deal on doing the steering rack with LCA's. Half the work on each is shared, shouldn't pay twice for it.
Get OEM LCA's, or atleast the OEM bushings if your ball joint is still good. But at that mileage, buy whole new units.
Make sure they tighten/torque while the vehicle is on the ground. So the suspension and arms are in their normal state. If they tighten while on the lift you'll destroy those new LCA's in very short order and they'll clame it was the product.
As far as touching other stuff while in there, I'd have them check wheel bearings and the CV's.
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 12:57 AM #8
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
might be pretty expensive if the mechanic wont be able to take out the alignment cams. They are famous for getting seized. I had to spend an extra 2 hours getting one cam out that was stuck on my 4runner.
pahaf91 is offline   Reply With QuoteReply With Quote
back , lot , rack , steering , y’all
'98 4Runner Steering Issues: New Rack or ITRE's and Rack Bushings? TheFriZ 3rd gen T4Rs 23 04-25-2019 12:35 AM
Steering rack bushings bad Difflock 3rd gen T4Rs 7 08-05-2017 04:00 PM
Will the coil overs from a 2007 Taco fit our 4runners? toku58 3rd gen T4Rs 15 01-25-2015 02:13 PM
new to 4runners need advise lensp4 3rd gen T4Rs 7 06-05-2014 04:19 AM
help with rack bushings francob 3rd gen T4Rs 4 10-05-2007 08:49 AM
