Old 08-18-2019, 07:33 PM #1
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
Rear brake pad question
i recently had a service done at the dealer, and as usual, they did a multipoint inspection. for the rear brakes, they came up with 6,6,6,3 for pad measurement numbers. they said one of the pads had come loose (or something to that effect).
they recommend a full rear brake job, eventually. i haven't confirmed the issue, but was wondering if this is common enough issue (legitimate), what the probable causes are, and if with 50% pad left on most, could just a pad replacement suffice. they don't think it is a caliper issue (original) because wear is only occurring on one pad.
rwh963 is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 08:35 AM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
The rear brakes are 2-piece units, with a stationary bracket and the floating caliper mounted to the bracket on slider pins.
I've seen pad wear variation when one or both of the sliders seizes, either due to failure of the rubber boot (water incursion and resulting corrosion) or lack of lubrication. Similar failure modes when the caliper piston seizes in the bore.
No idea what they may have meant by the pad coming loose.
I'd unbolt the caliper and inspect for proper slider pin movement, and piston smoothly retracting into the bore. Also inspect the rotor surface for indication of overheating, e.g. black discoloration on the friction surface.
waypoint is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 08:36 AM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
If a pad is wearing faster then others it is typically due to caliper failure. Pad replacement would just be a band-aid and in a couple months you would be right back to where you are now if they can even reuse the caliper. If they said the pad was loose then they should be able to tell that the piston is seized as long as it is mounted properly..
Brakes are a big safety factor, not somewhere I would be comfortable with going the cheap route..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 06:07 PM #4
[QUOTE=UrbanRunner651;3341370]If a pad is wearing faster then others it is typically due to caliper failure.
i asked about the calipers, and was told that the tech recommendation was pads and rotors, and not calipers at this time.
i will be going elsewhere for a tire rotation, and they will inevitably do a multipoint inspection, so i will see what they come up with.
i've had many questionable suggestions by dealers over the years to be skeptical.
Old 08-19-2019, 07:27 PM #5
4Runnergenius 4Runnergenius is offline
Real Name: Chris
4Runnergenius is on a distinguished road
Real Name: Chris
[QUOTE=rwh963;3341767]
Dealers and Techs are their to make money sad to say they sometimes don't do the right thing, I do agree the issue is probably a sticky slider so a pad replacement only won't fix your problem. get a second opinion
4Runnergenius is offline   Reply With QuoteReply With Quote
brake , common , issue , pad , rear
Rear brake question xtoy4runner88x 5th gen T4Rs 9 01-03-2018 05:01 PM
Rear Brake guide rod question, and brake shudder question snukkums 4th Gen T4Rs 5 09-14-2017 03:44 PM
Rear brake question Devo9000 3rd gen T4Rs 7 08-16-2017 04:05 PM
Rear Brake Adjust Question mvonwahlde 3rd gen T4Rs 1 07-22-2010 08:33 PM
rear brake question xnapajx 4th Gen T4Rs 1 11-07-2005 02:28 PM
