Old 09-05-2019, 07:46 AM #16
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Originally Posted by MikeinNH67 View Post
Yeah, the tensioner looks to be a bear. I didn't notice 2 bearings in that pulley so maybe it's been replaced in the past. I did notice 2 in the lowest one.
Now that you mention this, my truck was bought used and the pulley I removed last year during the timing chain project may not have been factory. (Have to remove the tensioner pulley to access the water pump bolt behind it.)
The tensioner on it now is an AC Delco part installed during the timing chain replacement, and it has 2 bearings like the #1 lower idler pulley. This tensioner pulley failed after a year and ~30K miles, it's junk. The lifetime warranty via Rock Auto is useless on a weekend when you need the vehicle for work on Monday...lesson learned.
Good luck w/ yours, let us know how it goes.
waypoint is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 02:29 PM #17
The Yin's Avatar
The Yin The Yin is offline
The Yin is on a distinguished road
The Yin's Avatar
Not there yet . . .
So I replaced all of the pulleys, even the one on the tensioner. It took longer then it should have cause I kept have to go back and confirm details (location of pulleys and torque). I had my head gasket replaced over a year ago, and they swapped the #1 with the top left #2, so that throw me off as I was part comparing.
Anyway, I got everything back together and it's working. But upon closer inspection I noticed the real issue. My belt tensioner itself is giving out. I watched and could see that the sound would happen when the tensioner was bouncing a little. Seems the spring is just weak after 130k+ miles and 14 years.
Seen here: 20190929_151233.mp4 - Google Drive
At least one pulley (top right #2) had bad bearings, but now I'll be having a mechanic friend replacing the tensioner. I would tackle it myself, but wont have the time before and up coming road trip.
-The Yin
2005 T4R Sport V6 2wd
The Yin is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 11:47 AM #18
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
yep, that is what I suspected.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 08:35 PM #19
MikeinNH67's Avatar
MikeinNH67's Avatar
Mine now seems to be quiet after a new tensioner pulley.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-07-2019, 02:36 PM #20
The Yin's Avatar
The Yin's Avatar
It was indeed the tensioner
Had the tensioner replaced and that took care of it.
For anyone that might have this problem show up, take the time to watch closely if your tensioner is moving at all. I would have IDed this faster if I had.
-The Yin
clipping , fine , make , sound , work
Chirping sound after Timing belt/water pump/3 drive belts service NoVA_T4R 3rd gen T4Rs 2 06-07-2016 02:02 AM
Chirping sound coming from dash atlanta4runner 5th gen T4Rs 8 04-27-2015 02:24 AM
'01 Chirping Sound MattAK 3rd gen T4Rs 0 01-31-2014 08:08 PM
07 v8 under load chirping sound Newyotaguy 4th Gen T4Rs 6 03-21-2013 09:33 PM
Chirping sound? dat5574 Problems & Warranty Issues 1 10-04-2010 11:01 AM
