Old 08-26-2019, 05:41 PM #1
The Yin's Avatar
The Yin The Yin is offline
The Yin is on a distinguished road
The Yin's Avatar
Clipping or chirping or chattering sound from under hood
I've got a sound that I'm sure is somehow related to something in contact with the driver belt. What? I'm not sure. It's a clipping or chirping or chattering sound (sorry, no video yet.)
Today I was able to make the sound Start or Stop by turning On or Off my AC. Other times it seems to start when I turn the wheel, but stop when I'm not turning.
Power steering and AC work fine. I haven't tested to see what voltage I'm getting to the battery when the truck is on, so I don't know if it could be the alternator. The water pump was just replace a year ago.
The sound comes and goes, it's not constantly there when the engine is running, so I don't think it's a idler of any kind.
Everything seems to work fine, AC, PS, engine temp is good, haven't had problems with it starting, so I'm assuming the Alt is charging the battery.
Are there any particular parts the would make an intermittent sound like that when they are failing?
-The Yin
2005 T4R Sport V6 2wd
The Yin is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 05:45 PM #2
08TxRunner 08TxRunner is offline
08TxRunner will become famous soon enough
Idler pulleys and tensioner pulley more than likely. Not unusual for the A/C to make it worse since it adds load to the belt. There's a good Gates kit on Rockauto to replace them all.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 05:56 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Mine has a chirping noise that comes and goes, but its from the AC blower motor. Turning the motor up makes it chirp faster, turning it off completely kills it.
But I could see where it could be from a pulley as well.
2005 4R Sport 4WD "The last of the V8s!" - Custom TIG'd SS Dual Exhaust - Icon 2.5 Resi's. - 1.5" BL - SCS SR8's - 35's - Dana 60 - Build Thread
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 06:02 PM #4
The Yin's Avatar
The Yin's Avatar
idler test?
All the idlers should spin freely right?
I might just pop the belt off and spin them to see if any feel restricted.
-The Yin
Old 08-26-2019, 06:20 PM #5
Bullit_Sponge Bullit_Sponge is offline
Real Name: Andrew
Bullit_Sponge is on a distinguished road
Real Name: Andrew
Could also be the belt itself. You don't say when it was last changed, but it does make noise with various accessories engaged, AC, power steering (when turning). You could try a belt conditioner but if it looks cracked I would replace it asap.
Bullit_Sponge is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 06:41 PM #6
The Yin's Avatar
The Yin's Avatar
Just checked my Rockauto orders, the belt was replaced just over 2 years ago, maybe 25k miles on it.
And now that I think about it, there was an idler that wasn't spinning as well as the others when I replaced the belt. . .
-The Yin
Old 08-26-2019, 07:13 PM #7
nevada's Avatar
nevada nevada is offline
nevada will become famous soon enough nevada will become famous soon enough
nevada's Avatar
how old is the belt? I would guess it just needs replaced. mine was doing something similar recently. I believe it was the OE belt. 130k on it. a new belt, and all was quiet.
if its a recent belt, then I would suspect the tensioner. when they get old/worn, they cant quite keep enough tension on the belt, and will let them slip a bit. that is the noise you are likely hearing.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 07:53 PM #8
MikeinNH67 will become famous soon enough
Bingo. Mine is chirping too, pulled the belt and the lowest pulley is not smooth. The rest I pulled awhile back and lubed. The bottom one is a double bearing setup so no way to lube it without pressing the bearings out which is not worth the time.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-27-2019, 08:24 AM #9
Keep in mind that spinning pulleys by hand is a good way to find a really bad pulley, but it won't necessarily always find a bad one. I've had bad pulleys that seemed fine spinning by hand but were obviously bad when the belt was on.
Old 09-01-2019, 03:58 PM #10
Well, this was a fail on my part. I bought 3 idlers in a kit and installed them thinking the bottom one is the noise maker. Nope, noise is still there. I pulled the 4 nuts off the clutch fan as I have had one of these on another vehicle make noise and it's not that. Yes I did put the nuts back on as the pulley would be loose without them. The noise is also there with the A/C on so I'm thinking that is fine. Now I'm contemplating changing the tensioner. You can see it move side to side as the belt spins, makes me wonder if that slight movement is a squeak. That tensioner pulley did not come with the kit.
Mike
03 4runner Limited
Old 09-03-2019, 01:34 PM #11
The Yin's Avatar
The Yin's Avatar
Hmmm, I think I see which idler is the the problem. I haven't taken anything off to check, but this much movement doesn't seem good.
Click to see video on Flickr.
[IMG]idler action [/IMG]
I'll just replace them all anyway. After the 136K+ miles, it might be time.
-The Yin
Old 09-03-2019, 05:42 PM #12
waypoint's Avatar
waypoint waypoint is offline
waypoint will become famous soon enough waypoint will become famous soon enough
waypoint's Avatar
I just posted my experience from last weekend w/ a bad tensioner pulley. NAPA part # 36174, or Gates same part #, fits correctly and fixed my noise. I went nuts swapping in my old spare idlers before I found the tensioner pulley as the squeak/squeal. It had no detectable play, and seemed to rotate smoothly by hand.
waypoint is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 03:29 PM #13
That's how mine is, seems fine. So you replaced only the pulley itself? I was contemplating replacing the whole unit with the unit below. Thanks for the info!
https://www.amazon.com/Dayco-89371-B...Toyota+4Runner
Mike
03 4runner Limited
Old 09-04-2019, 06:47 PM #14
waypoint's Avatar
waypoint's Avatar
Yup, just the pulley for this fix. The stethoscope clearly showed the pulley bearings as the noise source, otherwise I'd have replaced the whole tensioner.
Interestingly, the Toyota pulley has two separate bearing assemblies pressed into it. The Gates replacement has only one, longer bearing assembly. Seems to put more bearing surface area than the factory design. Whether the bearing components are same/better/lower quality relative to the Toyota part is unknowable...but the Gates pulley has a lifetime guarantee.
Changing the tensioner is a bear. Have to remove the AC compressor to get to the tensioner bracket. And probably have to remove the alternator to get the AC compressor moved. Unbolting the AC compressor, even with the fan, radiator, alternator, and other front components removed is a PITA.
Old 09-04-2019, 06:55 PM #15
Yeah, the tensioner looks to be a bear. I didn't notice 2 bearings in that pulley so maybe it's been replaced in the past. I did notice 2 in the lowest one.
Mike
03 4runner Limited
clipping , fine , make , sound , work
Chirping sound after Timing belt/water pump/3 drive belts service NoVA_T4R 3rd gen T4Rs 2 06-07-2016 02:02 AM
Chirping sound coming from dash atlanta4runner 5th gen T4Rs 8 04-27-2015 02:24 AM
'01 Chirping Sound MattAK 3rd gen T4Rs 0 01-31-2014 08:08 PM
07 v8 under load chirping sound Newyotaguy 4th Gen T4Rs 6 03-21-2013 09:33 PM
Chirping sound? dat5574 Problems & Warranty Issues 1 10-04-2010 11:01 AM
Copyright © 2019
