Old 08-27-2019, 02:58 PM #1
TheHennDoggg's Avatar
TheHennDoggg TheHennDoggg is offline
Real Name: Henry
TheHennDoggg will become famous soon enough
Real Name: Henry
Solo Evap Core Replacement- DONE! Pics and Info
Hello everyone,
-------Story Time!------
I have been filling the freon in my 4runner's air conditioning system every 3 or less months for a very long time. After a long 2 week family vacation, I fired it up and was greeted with a VERY strong "hairspray" smell and very warm air. I tried a DIY kit and put a total of 36 ounces of freon in over the course of a month, filling it up as it leaked out. It just got worse, and now I couldn't use the heater because this smell was so overbearing I could not run the fans!
I stopped putting freon in and sucked up the summer hour-long commute until I got back to school (good thing that back window goes down !)
Researching the symptoms led me toward the "dreaded" evaporator core replacement, which feels like is referred to in hushed whispers and there is a surprising lack of any detailed information on the process. I want to keep this vehicle for as long as I possibly can, so of course I'm going to fix it. But $1900+ dollars??? Hell no! I'm in this to do myself.
QUICK INFO
This job took 5 days on and off, approximately 25 hours, which is embarrassingly slow. Unfortunately, I am not the most experienced and I also did this job completely alone. I am 21 in college and also did it all outside during a rainy week. Womp womp
Total cost: $300
DENSO 4760040 (evap core) $89
FOUR SEASONS 39143 (expansion valve) $21
UAC RS2584 Rapid Seal Oring Kit $20
Harbor Freight Vacuum Pump $80
Refrigerant $40
1 Gallon of Cherry-Flavored Coolant $17
Scribes $8
Screwdrivers $8
Mother's VLR $7
First Step is to download that thicc factory service manual. I have all of the relevant pages snipping- tool'd into a pdf but cannot get it to post even though it is under the size requirement. I'll post it later in the thread when I find out how.
Next buy some parts! I slid over to Rock Auto and bought a few things shown above.
Now the fun begins. For the love of God, make sure your passenger and driver seats are motored all the way back before you take the battery out. I did NOT have a lot of space and i realized way too late.
Take that battery out and we can start disassembling the heater and refrigerant from the firewall. Evacuate the refrigerant system either illegally by depressing the schrader valve on the low side and shooting everything out into the atmosphere, or responsibly at a shop.
Go to the heater side and get some pliers and undo the hoses. A solid amount of coolant will come out, so you might wanna try to mitigate the spillage. Here is a good vid on how I did it: YouTube
Next, the refrigerant side is a lil funky. You have these 2 weird Toyota quick disconnects which the manual states you need a Special Service tool to conquer. This is not the case as demonstrated in this video: YouTube
That's why i went and bought some scribes from WalMart so I can poke at it to get them off. Make sure to PULL the lines away from each other, not deform them with a screwdriver. And put a rag on your hand, because if you evacuated it the illegal way, there's a good chance there is still a little cold juice in there trying to make your fingers into ice.
Here is my gallery of the teardown: 2003 4runner V8 Evaporator Coil Replacment - Album on Imgur
Edit #1: 8/31/19
Alright, so you're done in the engine bay and if you're anything like me, I have never evacuated a system, disconnected refrigerant hoses OR opened up any of my 4Runner's cooling system. This is when I started second guessing myself, because these were "givens" that I didn't see anyone talking about (like the quick disconnects??). But seriously, you can do this job if you just have time on your side.
Next step is when the "scaries" happen and you need to play with bombs. If you have taken your battery out before you did that firewall work, it should be plenty of time to start ripping stuff apart.
Get a big torx bit (I forget which one) and an impact wrench if you have it to get the steering wheel nut off
Follow the steps on how to take a steering wheel off in this document:
Dash Removal.pdf - Google Drive
This document is simply the pieces of the factory service manual I found relevant to this job in (mostly) the correct order. This will bring you roughly to the end goal, but there are a few things that really suck along the way.
The first one being the REALLY hard to disconnect airbag connectors. Good thing there are only 2. You will see your first after you take the steering wheel off and get to the spiral cable. I found the easiest way to disconnect them is getting a flathead screwdriver and pushing the "flat" part forward and just slightly in. As far as I can tell, the easy-to-push part is just a red herring that caught my attention for way too long until i pressed on the flat part.
You probably do not need a steering wheel puller, it is handy, but I was able to get mine off by just rutchin' it around.
So you keep chuggin' along on that document for awhile, most things are pretty strait forward until its time to rip out the dash. Remember, you must have BOTH A-pillar trims removed to make it possible to yank out and a kinda- secret bolt I missed that is in the upper part of the void the glove box used to fill. Not the latch bolt, but more up and toward the firewall. Ask me how I remember
The dash will come out pretty easy if everything is removed the way it needs to. I don't remember the clamps at the firewall being "hard" to pull out.
Theeeen your stress levels rise because instead of a dash being in your car, there's basically metal and a big ol' wiring harness. But now your target is in sight: that big white box that seemingly the entire interior was built around.
Also you better be taking pictures starting now, because even though you have mine, you will ALWAYS wish you had more. Get your Ziploc bags too and label them when you get done with a small section.
Dropping the steering column sucks because when you do, you will almost CERTAINLY lock it in a new position than the way it fell off. The only problem I found with this is that it is a bit harder to reinstall and the steering wheel will be crooked as hell when you put it on "strait" the first time. Just turn the car on (when everything is done of course), recenter the front wheels and put the steering wheel on AGAIN with the clock-spring and wheel centered.
You're STILL chugging on the document, taking pics and correctly labeling groups of nuts/ bolts and stuff you take off. You're also probably cursing Toyota for the step that states "release the 27 clamps". I know I was, and I don't really have anything there to help you. You just gotta find all of them and not break at least half.
Then its time for removing the dash core support. You take out the 5 bolts, give it a tug, and no go. Didn't you just take every single nut out of the entire interior?? Why isn't it moving?
Its because its also kept in place by that white box you wish didn't exist. I personally took a hammer and lightly tapped up and out on the bar for awhile and it broke free. Then please get a buddy to lift it out with you because I scratched the hell out of my driver door doing it myself. Metal beats plastic any day.
BIG REMEMBER/WARNING
REMEMBER that this core dash support needs to go into THREE slots on the top of the white airbox/ blower box when FIRST placing it in. Not 2, not 0. I messed this up and wondered why my dash didn't line up with the holes on the core support. Guess who had to reinstall the dash twice. The manual doesn't expressly state that it has to go in those grooves, and I just forgot and went on with my day.
Post is incomplete and still in progress!
This will end up being a long post and it has gotten long already, so I will post and edit it as I go along. I am happy to answer any questions you might have!
Ask me about my frame rust!
Major Parts List:
Energy Suspension, full front end rebuild, 885& Toytec, SPC upper arms, dual-amped 7 speaker stereo, 5100's, rear swaybar delete courtesy of rust, v6 junkyard skidplates and a lot of elbow grease
TheHennDoggg is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 06:44 PM #2
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Respect
BigMike18 is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 07:35 PM #3
Jeckolame Jeckolame is offline
Jeckolame is on a distinguished road
Nice
Jeckolame is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 06:07 PM #4
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Dude, you're my hero! Please continue with the steps before you forget!
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 08-31-2019, 06:55 PM #5
Real Name: Henry
Real Name: Henry
Edit 1 is almost complete! I hope this has helped you so far!!
Major Parts List:
Old 08-31-2019, 06:57 PM #6
Real Name: Henry
Real Name: Henry
Also, if anyone has any tips with dealing with airbag warning lights, please tell me! I thought it was very simple to reinstall the airbags and harness. After all, they are bright yellow and literally idiot proof to put back in, but I seemed to have messed it up. How to I check these codes and where could I check to find failure? Everything is 100% except for the light!
Major Parts List:
Old 08-31-2019, 07:25 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Have you had the codes read, if so what are the codes?
If not take it to an autoparts store, most will read the codes for free.
Are you sure you didn't damage the clockspring when removing the steering wheel?
If you're not sure it could be very well the issue if it got damaged.
2004 Limited V8
Old 08-31-2019, 08:18 PM #8
Real Name: Henry
Real Name: Henry
I tried to have the codes read at Autozone, Advanced Auto and O'reilley's. Unfortunately, all 3 said they couldn't, which is weird because I thought at least O'reilley's would. And I was very careful to not damage the clockspring, as I did understand they could be broken easily, but maybe it was damaged just from handling it.
I plan to trace all the airbag wires back since there are only 2 main ones and they are easy to get to. After that, maybe I will buy a cheap clock spring if I can't figure out what's wrong!
Major Parts List:
Old 08-31-2019, 08:27 PM #9
Real Name: Skip
Real Name: Skip
Check all the connectors for the airbags, even if they look connected correctly, disconnect them again and reconnect them, the same on the clockspring, it could be just a loose/poor connection even if they appear to be connected properly.
2004 Limited V8
Old 08-31-2019, 09:51 PM #10
Real Name: Henry
Real Name: Henry
Yep that's my plan, disconnect all airbags and reconnect all of them quick. I just tried the battery terminal trick and no dice. I still really doubt I broke anything, so I have high hopes! If no dice, I will try the clock spring
Major Parts List:
Old 09-01-2019, 07:38 AM #11
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
Incredible! Thanks for all your hard work on this.
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 11:24 AM #12
Real Name: Henry
Real Name: Henry
No problem, thanks for looking at it! I hope once it's done it can really get people on the right track and getting this PITA job done once and for all. It's just going to get more and more common, especially since old 4th gens are almost 2 decades old!
Major Parts List:
Old 09-01-2019, 01:10 PM #13
Real Name: Henry
Real Name: Henry
For anyone visiting this thread later, I have found and fixed my airbag problem. The connectors under the middle part of the dash can be pushed in and LOOK like they're in all the way, but I did not click in the passenger side one. Check your connectors before final assembly for sure!!
Major Parts List:
Old 11-12-2019, 12:18 PM #14
Real Name: Henry
Real Name: Henry
Strong smell again
Going into the colder months of winter, a smell of Freon greeted me as i turned on my heater. Hopefully it is just a fluke because the only thing in the air box that can leak is the evap core, the new expansion valve and o-rings are all located just outside. That means the brand- new DENSO unit has to be bad if the smell persists.
I still have compressor function and cold air no problem, so we will see.
Major Parts List:
Old 06-14-2020, 10:57 PM #15
dsanford dsanford is offline
dsanford will become famous soon enough
Any update?
2006 GGM Sport 4WD / Lots of maintenance from neglect (from previous owner) / Interior & Exterior LED swap / Sony XAV-AX1000, Kicker front door speakers, Kenwood tweeter replacement / Diode Dynamics SS3 Fogs
dsanford is offline   Reply With QuoteReply With Quote
back , good , long , make , post
4th Gen Evaporator Core Replacement TungstenSquash 4th Gen T4Rs 13 10-04-2020 01:24 PM
Need Info: Upgrading Stereo Head Unit - T8 Core vs Alpine ILX-F309 Toda R 5th gen T4Rs 18 07-25-2019 10:35 AM
Evap Core Help, heater related. JP1 4th Gen T4Rs 5 06-07-2014 03:08 AM
heater core replacement Lil Red Yarder Classic T4Rs 6 11-29-2011 11:25 PM
Morning solo run @ Slaughterhouse -CO many pics RonMAIDEN Gallery 15 07-07-2007 01:24 PM
