09-02-2019, 01:48 AM
New alternator blowing main fuse
2007 V8 4wd
Hi everyone, I just replaced the alternator (AutoZone reman) and battery on my 4runner and am having a problem. When I went to reconnect the battery it shorted and blew the main 140 amp fuse. My wife said she thinks she saw sparks from the area near the alternator and it definitely arced on the main battery post.
Any ideas what could have caused this? The connectors only go on one way and the wiring etc all looked to be in good shape. The battery was working fine before I pulled the alternator.
I'm going to get a replacement fuse tomorrow if anything is open but I'm concerned I'll just blow another one and possibly damage something important. Speaking of which I am really worried something may have fried. I didn't smell anything burning but still... The vehicle did start but wouldn't go into gear etc. with the blown fuse.
Any help is most appreciated!
09-02-2019, 01:54 AM
try another alternator, at least disconnect everything and go over all connections. might have missed a wire or new alternator just bad.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
09-02-2019, 02:00 AM
Is it possible to get to the connectors on the alternator without pulling it? I'd like to do that first before having to take the whole thing out again. That's a pain in the ass.
09-02-2019, 07:43 AM
+1
09-02-2019, 10:51 AM
Real Name: Bob
Real Name: Bob
It's possible to get a bad alternator out of the box, take it back.
09-02-2019, 12:13 PM
Thanks for the input! Look like I'm spending labor day pulling the alternator again. Gah.
09-02-2019, 02:58 PM
Ok so I found the problem. The hot connector on the alternator was touching the alternator housing and shorted. Should I replace the new alternator? I'm wondering if the electronics on it might be shorted.
09-02-2019, 05:03 PM
get another one, possible that the short could of cause some melting in that area. its lifetime warranty right if you got it from autozone or orileys.
while you doing the job again, i would also do the big 3 upgrade, never know if you need some stable power.
09-02-2019, 05:22 PM
I've already got it back in. Won't know if it's good until I replace the alternator fuse. No one local has it so ordered from Amazon. I did read of similar situations where the alternator was fine. The housing is barely marked and it is on a thick area with a bolt running through. Nothing on the inside there. Hopefully it's ok.
What is the big three upgrade?
09-02-2019, 07:36 PM
What is the Big 3 Upgrade - And How to Install it - Mobile Install Guide
theres also youtube videos on how to do it. sonicelectronix has one thats pretty good to watch.
09-02-2019, 07:41 PM
Real Name: MIchael
Real Name: MIchael
That fuse is near impossible to change without breaking the fuse box. Saddly it dosnt kust pull out.
