12-16-2019, 11:39 AM
#181
Real Name: The Native Explorer
For the second set of XBALED halos, this time in 120mm...
All it took was a little shroud slicing with the trusty dremel. *edit - it does sit perfectly flush, but isn't glued down yet... DON'T WORRY
And.... voila
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
12-16-2019, 12:11 PM
#182
Also blasted and painted a spare shroud from the OEM housing I broke earlier in this whole ordeal to get a feel for what I wanted to do, aesthetic-wise.
This is flat: I'll probably go satin in the real deal.
Loose test fit:
IG @apohl17
12-16-2019, 12:35 PM
#183
And then one more pic of the schwifty red LED's I slapped in the 5.0s...
IG @apohl17
12-17-2019, 10:47 AM
#184
Thinking about trying mineral spirits for removing the nasty TYC butyl rubber from the lenses... Anyone try that before?
IG @apohl17
12-19-2019, 01:05 AM
#185
Yay! Finally, blue-tinged iridium tips, glazed labeling, and much nicer manufacturing quality. You can DEFINITELY tell the difference between OEM and knockoff plugs. I went with the Denso IK20TT twin tips.
Here's a good seller on ebay:
Set of 8 Genuine Iridium Spark Plug Denso 4702 For Various Vehicles 1991-2015 | eBay
IG @apohl17
12-23-2019, 11:05 AM
#186
Spark Plug Change @ 215028 miles
First step- airbox begone.
IG @apohl17
12-23-2019, 11:07 AM
#187
2. Disconnect the coil pack connector
3. Remove the 10mm bolt holding the coil pack, remove
4.Spark plug wrench + long extension + swivel + another extension... Crack loose
IG @apohl17
12-23-2019, 11:09 AM
#188
5. Add a wee bit of antisieze to threads (optional)
6. Install to snug + 1/8 turn (ish)
7. Install coil pack, holding bolt, and electrical.
8. Repeat for all 7 others (happy?
@ AuSeeker
I'd say it was about due for new plugs! Feels a little better on acceleration and at idle in the cold temps here in Wisco.
IG @apohl17
12-23-2019, 05:48 PM
#189
Blasted and painted the shrouds satin black over the weekend...
IG @apohl17
12-23-2019, 05:50 PM
#190
... and FINALLY got the Butyl Rubber off the lenses!!!!
Took temperature. Lots of it, to be exact. Heat gun, pliers, burnt fingers, and beer to make it go faster.
IG @apohl17
12-23-2019, 05:51 PM
#191
Then mounted up the projectors and sealed up the backside of 'em! Got creative with the clear grommet supplied by Morimoto and the "OEM" black one. (pic shown with bulb for test fit)
IG @apohl17
12-23-2019, 05:53 PM
#192
And treated the rig to an Xmas hand wash... I should do this more often
IG @apohl17
12-23-2019, 06:30 PM
#193
Probably won't hop on until after the holidays- hope all you peeps have the merriest of holidays and a happy Christmas!
IG @apohl17
12-23-2019, 08:16 PM
#194
Real Name: Skip
Real Name: Skip
You only replaced one plug???
Most people replace them all!! LOL
2004 Limited V8
12-23-2019, 08:38 PM
#195
Yeah! Then I'll be changing that one same plug out every week with my other 7 brand new ones to flush out that cylinder. (kinda like a Tranny fluid flush).
My local pro shop said it was best to do it this way. I still have yet to fill up the blinker fluid reservoir with the gallon they sold me for $149.99....
IG @apohl17
