12-23-2019, 08:45 PM
#196
Real Name: Skip
Real Name: Skip
Originally Posted by apohl17
OK that's makes more sense, you definitely need to get that cylinder flushed out properly!
I would however jump on that blinker fluid ASAP, if you don't you will never be able to turn the steering wheel!!
2004 Limited V8
12-23-2019, 08:53 PM
#197
Real Name: The Native Explorer
NO WAY! So that's why my steering feels so funny. Unless it's normal to have the rig do a crisp U-turn whenever a large retail store, jam-packed with last minute shoppers, rampaging un-attended children, and electric mobility cart-riding elderly comes into sight... Idk, I might let the blinker fluid run low like this for a while!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
12-30-2019, 12:26 PM
#198
Got the retros buttoned up over the weekend!
But first, let's screeee our way back to showcase the last few steps before "completion"...
Step 642: 1 Minute Epoxying the halos onto the Profile Hi-Lens LED's
Step 987: Button up the backside with OEM grommets and such:
IG @apohl17
12-30-2019, 04:51 PM
#199
The splitters I used to connect the OEM high beam outputs to both the high beam solenoid and the Profile Hi-Lens on each side of the truck.
I'll post a diagram of the wiring at some point, but it was pretty straightforward. The only big difference than my last retro would be the quad highs and the fact that I bought D2H bulbs to match the ballast wiring...
IG @apohl17
12-30-2019, 05:33 PM
#200
IG @apohl17
12-30-2019, 05:34 PM
#201
Obviously I needed to still adjust these vertically, but dang, I like the cutoff on these 5.0's... And I'm purposely not posting a picture of the quad highs because it's too cool for school
IG @apohl17
12-30-2019, 06:25 PM
#202
Step 89245897928457: Clean the inside and outside of the lenses, blow out any dust from the housings that might have settled over the 6+ consecutive weekends it took you to wrap this project up, etc, etc, etc...
Once you get there, start bolting the suckers back together - but first, lay a nice strip of awesome Morimoto RetroRubber around the groove in the bucket:
And then heat 'er up and glue 'er back together!
IG @apohl17
01-02-2020, 12:39 PM
#203
yay
IG @apohl17
01-02-2020, 04:38 PM
#204
yay
Those high beams must be gnarly!
01-02-2020, 04:50 PM
#205
I have no idea what is going on in this thread but I like it. I'm just enjoying the nice pictures.
01-02-2020, 04:53 PM
#206
Real Name: Michael
Real Name: Michael
Same
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
01-02-2020, 05:12 PM
#207
Lows:
And the indubitably gnarly quad highs.
IG @apohl17
01-02-2020, 05:14 PM
#208
Originally Posted by That_Titanium_4RNR
Same
Just one 4runner lunatic and his weekend mods. What else would you expect?
BTW,
@ Inv4drZm
thanks for letting me on to Flickr. Definitely helps with keeping pic quality through hosting and posting!
IG @apohl17
01-03-2020, 11:08 AM
#209
For referencing purposes, here are a few details I skipped over:
Routed the wires under the radiator shroud for the relay harness, which includes the passenger ballast, igniter, and halo.
Halo DRL test fire:
Buttoned up in the shop:
IG @apohl17
01-03-2020, 11:11 AM
#210
Semi-final operation...
Off:
DRL mode (first position on stalk):
Low beams + DRL (second position on stalk):
High beams + DRL (second position, slicked back)
IG @apohl17
