01-06-2020, 12:53 PM
#211
Real Name: The Native Explorer
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
01-06-2020, 12:55 PM
#212
Installed it in the frontmost slot which really is necessary to keep the front end from vibrating due to wind. I wanted to keep it open for sunroof access, but it didn't work that way. I still have lots of room though!
IG @apohl17
01-08-2020, 11:49 AM
#213
Got a call from a manufacturer today that my something something I ordered back around Thanksgiving is getting powdercoated soon!
Mmmm, me likey... :rockon;
IG @apohl17
01-10-2020, 08:52 AM
#214
Down in Indy for the ATA Show - any bowhunters/archery nuts on here?
IG @apohl17
01-15-2020, 11:15 AM
#215
I have been having a little rear end clunk at slow speeds, seemingly suspension related. Popped the rig up on the lift, didn't find anything out of the norm... Greased up the driveshaft and front UCA's while I was at it. Will keep an ear on it!
IG @apohl17
01-15-2020, 12:40 PM
#216
Have you checked the rear sway bar bushings/brackets?
01-15-2020, 01:05 PM
#217
That's kind of what it has to be - something sway bar related. I have MStudt links on the rear so the end links aren't the issue, but the bushings themselves are likely OEM and probably could use a refresh or two. I know they visually didn't look bad, but that worn out rubber back there could very well be causing my mystery clunk. It's not super loud, but noticeable every once in a while...
IG @apohl17
01-15-2020, 01:55 PM
#218
Are you not able to use the sunroof now with the extra bar in front? Was the vibration and noise that bad that you needed extra bars?
01-16-2020, 02:16 PM
#219
Oh no - sunroof is completely operation both ways still. The front end of the rack would shudder and vibrate (and even creak in subzero temps) under wind load at highway speeds without a bar in the frontmost slot - I could have used one of the supplied bars but I wanted to beef up the back end for mounting my RTT (which I am working on, slowly).
It's well designed from the get-go! I just like to modify and be different...
IG @apohl17
01-22-2020, 11:05 AM
#220
Been cold here, so not a lot of recent mods. Just enjoying the new output up front, that's for sure!
IG @apohl17
01-24-2020, 10:56 PM
#221
Keep it up !
03 4runner V8 4x4
12 GX460
17 Tacoma OffRoad
01-24-2020, 11:02 PM
#222
Originally Posted by roy326
Keep it up !
You got it man
Can't wait for spring...
IG @apohl17
01-26-2020, 11:42 AM
#223
IG @apohl17
01-26-2020, 11:43 AM
#224
IG @apohl17
01-26-2020, 11:49 AM
#225
IG @apohl17
