Old 11-07-2019, 11:30 AM #106
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Snow, Ice, 11 degrees. Woohoo
1106190639b
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 09:11 AM #107
apohl17's Avatar
apohl17's Avatar
Always a good sight to wake up to...
Hint, it's a slab of steel
Apohl17's AventuRunner Build Thread - V8 4th Gen-capture-jpg
IG @apohl17
Old 11-11-2019, 09:22 AM #108
apohl17's Avatar
apohl17's Avatar
Ditch Light Installation
Components:
- Mindwerx LED Lazer Pods link to eBay
- @Caliraisedled Cali Raised LED Tundra P/C Ditch Brackets link to their site
- Cali Raised LED Amber Ditch Lights Switch link to their site
- Extra 3-wire cable( for switch extension), crimps, tools, etc.
H
IG @apohl17
Old 11-11-2019, 09:26 AM #109
apohl17's Avatar
apohl17's Avatar
Step 1: Start by bolting on the brackets under the hood to the OEM bolt locations. Since these brackets were designed for the Tundra, I found it optimal to add a single 1" washer above the ditch bracket on the back bolts (closest to the wiper blade). Talk about low clearance!
HHH
IG @apohl17
Old 11-11-2019, 09:31 AM #110
apohl17's Avatar
apohl17's Avatar
H
Then, start running wires. I already had wiring going to my grille, so I matched that on the driver's side, and made did similar wiring on the passenger side. The harness was PLENTY long...
HT
Make your connections (+ Red) to the center post and (- Black) to one of the surrounding small bolts.
H
Next, I opened up the console for running wires, as I wanted my switch to take the place of the DAC button (which I never use). Pop the wire in through an existing hole in the firewall grommet with the help of some soap and install the switch in your favorite location!
HTT
IG @apohl17
Old 11-11-2019, 09:34 AM #111
apohl17's Avatar
apohl17's Avatar
Check for clearance once bolted up, as well as for hood alignment...
H
H
H
H
IG @apohl17
Old 11-11-2019, 09:36 AM #112
apohl17's Avatar
apohl17's Avatar
And lastly, replace those plastic thumb studs for some real stainless M4x10mm button heads! A worthy $3.80 addition from the local hardware store... (shown as comparison here, don't worry - they all were switched out)
H
IG @apohl17
Old 11-11-2019, 09:46 AM #113
apohl17's Avatar
apohl17's Avatar
Big shout out to @Caliraisedled for the bracket recommendation - they fit awesome and are the low clearance hood mounted droid I was looking for. The Mindwerx pods light up the night, and I'll be fine tuning the angle and rotation over the next few nights. These things are going to be awesome for seeing deer...
1111
IG @apohl17
Old 11-11-2019, 12:15 PM #114
apohl17's Avatar
apohl17's Avatar
Forgot to mention, I did cut down the original mounting bolts included with the pod brackets so I didn't have as much thread extended below the lower nut. Mostly aesthetics, but did help for bracket install as well!
MindWerx Lazer
IG @apohl17
Old 11-11-2019, 04:37 PM #115
apohl17's Avatar
apohl17's Avatar
Made a thread for these brackets so the rest of you peeps know they are there. Very happy with them!
4th Gen Hood x Tundra Ditch Brackets
IG @apohl17
Old 11-11-2019, 05:17 PM #116
apohl17's Avatar
apohl17's Avatar
One more.
1112
IG @apohl17
Old 11-14-2019, 09:16 AM #117
apohl17's Avatar
apohl17's Avatar
That's the way, mmhmm mmhmm. I like it!
Skid
IG @apohl17
Old 11-14-2019, 09:20 AM #118
apohl17's Avatar
apohl17's Avatar
Only thing I did right away before fitting it to the truck was clean up some of the laser slag that occurred when the logo was cut out, because the dremel was handy. THIS THING IS BEEFY. I'll be posting lots more pictures, when I mount to verify fitment, clean it with acetone, go to paint, and eventually the final install, etc.
Before:
Skid
After:
Skid
IG @apohl17
Old 11-14-2019, 10:03 AM #119
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
nice...i have that skid on my radar too
hinmo24t is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 10:21 AM #120
apohl17's Avatar
apohl17's Avatar
Assuming it bolts up nice and the holes all line up on my V8 (hence the reason I asked them to take out the trapdoor on mine), it's a lot of steel for a great value. I'm hoping to have it on this weekend...
IG @apohl17
4th , aventurunner , gen , iceberg , thread
Apohl17's Iceberg Build Thread apohl17 3rd gen T4Rs 190 02-26-2020 01:00 PM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
