10-03-2019, 02:30 PM
#61
respect, you dig into it!
10-03-2019, 04:03 PM
#62
Real Name: The Native Explorer
Thanks mate!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
10-06-2019, 01:34 PM
#63
Got my stereo installed and my wiring finished up for anytime backup cam! Did this on my 3rd Gen, and won't go back to another vehic without Android Auto and eyes on the back of the rig...
Parts list:
Kenwood DDX6705S Stereo
Crux SWRTY-61S SWC Harness
CCD Backup Cam - link here
3ft RCA Male-Female RCA extension
Metra 95-8202 Dash Kit
Scoche MDAB Micro antenna adapter
Metra UV43 Antenna Y- splitter
Female RCA to Aux 3.5mm Y adapter
Optional:
Scoche MAGDMB magnet phone mount
Step 1. Start removing trim on the console area
2. Move up to the dash, a few 10mm bolts and a bunch of clips, boom.
3. Head unit, see ya!
Sent from my VS988 using Tapatalk
IG @apohl17
10-06-2019, 01:39 PM
#64
Steps 4-9. (the longest part)
Connect and verify all of the wiring connections between the Crux harness, stereo, backup cam, and mic. I use closed end crimp terminals after twisting the wires together.
10. Transfer the brackets and the plastic side plates from the Metra kit to the new stereo
11. (not pictured, did this previously) run the backup camera wiring along the driver side floorboard wire channel, three wires - RCA for video, ACC power so the camera is always on, and reverse signal to the yellow/red wire for automatic switching in R.
12. Connect and verify before making this tidy
13. Tidy up with tape so it isn't so messy behind the dash, then carefully push it into place!
14. Voila. Test for functionality, check all speakers, mic, USB, SWC, and aux functionality before buttoning all the trim up in reverse order!
15. Lastly, measure out the reverse cam distances for referencing. For me, the bottom of the screen was 2ft from the hitch and the middle yellow line across the screen was 4ft. Schweet.
IG @apohl17
10-07-2019, 08:15 AM
#65
So I keep going back and forth between posting pictures from Tapatalk on my phone and uploading them as attachments on the computer and tbh, i'm disappointed in both methods as of late! Tapatalk started to severely reduce image size and upload one at a time, whereas the forums here make me reduce the size to something ridiculous in able to post, then the pictures are almost too large on the screen to look at normally.
Oh, and Photobucket is
Anyone want to tell me any tips for posting full, or at least half res pics so my future images aren't a chore to look at???
IG @apohl17
10-14-2019, 01:16 PM
#66
Took a couple pics with the ol' FLIR attachment after a 3 hour highway drive. 40 degrees out, and max temps were in the 110-120s on the tailpipe. I mainly did this to check my CV joints, as I still have a bit of noise from the front passenger side and I'm skeptical of the non-OEM CV that was installed by the PO a year or so ago. It was reading about 30 degrees higher than the OEM, so it might be at least due for a regreasing or something... Or I just swap in a rebuilt OEM...
IG @apohl17
10-14-2019, 04:04 PM
#67
After photobucket died, I went to Flickr and have been happy with it ever since.
10-14-2019, 04:14 PM
#68
Good to know man. Gonna have to check that out. I assume the free version is good enough for what ya use it for? Looks like she be $50 a year for the "pRO vErsIoN"...
IG @apohl17
10-14-2019, 04:23 PM
#69
I think you get 1000 images with the free version, and I've gone over that so I'm a pro now.
10-23-2019, 10:45 AM
#70
Attaching some pictures from my recent endeavor just outside of Golden, CO...
Let's see how this Flickr thing works!
IG @apohl17
10-25-2019, 12:54 PM
#71
Went and tossed a bunch of bird pictures on a new thread so this one can be more focused on the Runner! Go check it out and post your pics.
The Neature Picture Thread
IG @apohl17
10-26-2019, 08:23 AM
#72
Next, switch out and retorque all the lugs. After removing the front passenger wheel to replace the center cap last weekend, I found out I had about 4 turns on the acorns. Not good!
Bought some extended Gorillas and replaced 'em all. Now i' m at 9 turns to snug. Muuuuch nicer!
Wow, I never knew those lugs existed. I’ve seen extended lugs before, but never with a conical seat. Do you have the part number and where you ordered them by chance? I have very few threads on my front wheels in particular with my Fuel wheels, and was planning to press in new studs, but that seems way easier and will do the rear as well, which is “ok” for thread engagement, but more is definitely better! Great build thread btw!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
10-26-2019, 10:25 AM
#73
Right on! Part #21134ETBC from Wheelers Offroad or Amazon is the 24pk gloss black version w/ the spline drive socket. You can also get a similar set from DP that are matte.
This is where I got 'em.
https://www.amazon.com/Gorilla-Autom...099517&sr=8-17
Thanks for the shout out!
IG @apohl17
10-26-2019, 05:24 PM
#74
Booted up my Mstudt rear links today to give them a head start on winter's wrath. Had to take two needlenose pliers and lube to pull them over the heims... Not as quick as I thought!
Also recieved word that my rack and skids should be shipping out next week.
IG @apohl17
10-28-2019, 10:42 AM
#75
Toying around with headlight options. Whipped out a quick #mspaint edit...
So I started with
@ jch0707
's rig w/ OEMassive DRL units
and did a little magic...
Hmmmmmmmm....I don't know
IG @apohl17
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
