Old 01-06-2020, 12:53 PM #211
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Ordered a 5 pack of 48" 80/20 bars to beef up the rack as well as make a mounting solution for my RTT. All I had to do was cut an inch off each one and tap the ends at 1/4-20 UNC. The miter worked wonders, then touched up the ends for sharp corners and burrs with a file.
CrossbarCrossbarCrossbar
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 12:55 PM #212
apohl17's Avatar
apohl17's Avatar
Installed it in the frontmost slot which really is necessary to keep the front end from vibrating due to wind. I wanted to keep it open for sunroof access, but it didn't work that way. I still have lots of room though!
CrossbarCrossbar
IG @apohl17
Old 01-08-2020, 11:49 AM #213
apohl17's Avatar
apohl17's Avatar
Got a call from a manufacturer today that my something something I ordered back around Thanksgiving is getting powdercoated soon!
Mmmm, me likey... :rockon;
IG @apohl17
Old 01-10-2020, 08:52 AM #214
apohl17's Avatar
apohl17's Avatar
Down in Indy for the ATA Show - any bowhunters/archery nuts on here?
IG @apohl17
Old 01-15-2020, 11:15 AM #215
apohl17's Avatar
apohl17's Avatar
I have been having a little rear end clunk at slow speeds, seemingly suspension related. Popped the rig up on the lift, didn't find anything out of the norm... Greased up the driveshaft and front UCA's while I was at it. Will keep an ear on it!
IG @apohl17
Old 01-15-2020, 12:40 PM #216
montijo505's Avatar
montijo505's Avatar
Have you checked the rear sway bar bushings/brackets?
Old 01-15-2020, 01:05 PM #217
apohl17's Avatar
apohl17's Avatar
That's kind of what it has to be - something sway bar related. I have MStudt links on the rear so the end links aren't the issue, but the bushings themselves are likely OEM and probably could use a refresh or two. I know they visually didn't look bad, but that worn out rubber back there could very well be causing my mystery clunk. It's not super loud, but noticeable every once in a while...
IG @apohl17
Old 01-15-2020, 01:55 PM #218
thuanvu thuanvu is offline
thuanvu will become famous soon enough
Are you not able to use the sunroof now with the extra bar in front? Was the vibration and noise that bad that you needed extra bars?
thuanvu is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 02:16 PM #219
apohl17's Avatar
apohl17's Avatar
Oh no - sunroof is completely operation both ways still. The front end of the rack would shudder and vibrate (and even creak in subzero temps) under wind load at highway speeds without a bar in the frontmost slot - I could have used one of the supplied bars but I wanted to beef up the back end for mounting my RTT (which I am working on, slowly).
It's well designed from the get-go! I just like to modify and be different...
IG @apohl17
Old 01-22-2020, 11:05 AM #220
apohl17's Avatar
apohl17's Avatar
Been cold here, so not a lot of recent mods. Just enjoying the new output up front, that's for sure!
IMG_20200117_222243_566
IG @apohl17
Old 01-24-2020, 10:56 PM #221
roy326 roy326 is offline
roy326 is on a distinguished road
Keep it up !
03 4runner V8 4x4
12 GX460
17 Tacoma OffRoad
roy326 is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 11:02 PM #222
apohl17's Avatar
apohl17's Avatar
Originally Posted by roy326 View Post
Keep it up !
You got it man
Can't wait for spring...
IG @apohl17
Old 01-26-2020, 11:42 AM #223
apohl17's Avatar
apohl17's Avatar
Some fresh edits:
T4RSNW (3)
T4RSNW (3)-OLD
T4RSNW (4)
T4RSNW (6)
IG @apohl17
Old 01-26-2020, 11:43 AM #224
apohl17's Avatar
apohl17's Avatar
T4RSNW (6)-OLD
IG @apohl17
Old 01-26-2020, 11:49 AM #225
apohl17's Avatar
apohl17's Avatar
T4RSNW (7)
IG @apohl17
4th , aventurunner , gen , iceberg , thread
Apohl17's Iceberg Build Thread apohl17 3rd gen T4Rs 190 02-26-2020 01:00 PM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
