Originally Posted by TNFISHRMAN
Guys I need a little help. Long story short, my tail pipe rotted off on my 04 v-8 4runner. Seeing how it is perfectly lined up with the rear axle, I basically boiled the rear gear oil while pulling my boat on a fishing trip. I made it home and change the gear oil out with fresh. I went out this morning to replace the exhaust system and notice a fresh gear oil drip at the Pinion seal on the rear differential. How bad is this thing to replace and is it possible to do without messing up bearing preload and gear backlash?
I doubt you "boiled" your differential fluid. It's 90W lube.
I recently changed my differential fluid at 135,000 miles with Valvoline 80-90W (conventional) - 3 quarts - and it took all of 30 minutes to drain and fill.
I don't tow with my 2005 SR5 4runner, but I like to fish here in the Bahamas.
Think the mahi landed in the Marlin Marine tournament is a record catch in any Hawaiian/California/Florida tournament?
See the wire to the tournament scale. 71.1 pounds?
If yours is leaking try Amazon.com for quick delivery of the rear differential gasket ($10.06). Free delivery.
Here's the link.
https://www.amazon.com/Yukon-Gear-YC...Toyota+4Runner
