Old 09-03-2019, 12:11 PM #1
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Bilstein 5100's w/ arb front bumper & V8. What to adjust to?
I come from the landcruiser world so front IFS on 4Runners is new to me.
I currently have 1" daystar spacers on 2016 tacoma struts. This was done to lift the front up since there is an arb bumper on there as well as the V8 motor weight. The shocks are blown out and when I hit a bump the ride is like a boat. This is not related to caster or alignment. When the truck is parked I can push on the bumper and it bounces a bit.
My friend gave me some used bilstein 5100's and their matching coils. I watched the video on their adjustment and how not to use them with spacers and rather adjust the coil top hat.
What height have people adjusted their top hat to with an arb bumper and v8 engine weight? I have a diff drop so I am not worried about CV angle.
Thank you.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 12:24 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Thank you.
Need to know what springs you're running. There are alot of options
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 01:30 PM #3
The coils are take offs and are used just as the 5100's are. They are off a 2009 4runner.
The goal is to run these for a bit until a toytex lift goes on later down the line.
I am curious what setting people use for heavy front ends (ie arb bumper and V8 weight).
Old 09-03-2019, 01:51 PM #4
Real Name: Michael
Real Name: Michael
I would guess 2nd clip would be about right. You could always just change the clip down the road if you aren't happy with it.
Old 09-03-2019, 01:52 PM #5
WildBill1990 WildBill1990 is offline
WildBill1990 will become famous soon enough
Stock coils with a heavy bumper are always going to sag. best intermittent option is to contact Dobinsons for some new front coils (possibly rears as well) and run them with the Bilsteins and chuck the spacers in the trash. Dobinsons has quite a few different options for coils and a pair will only set you back a couple hundred dollars. See @Dobinsons Mike page for 5% code.
WildBill1990 is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 05:03 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
No one here has addressed the spring rate.
You can adjust the height or change clip settings all you want, but if you are running the stock coils, it’s going to be under-sprung regardless of what you are doing.
The stock spring rate (on the V6) is about 600 lbs, at least that’s what my 6112 shocks shipped with. Eibach is the coil manufacture, and they make optional 650 and 700 lbs coils specifically to deal with things like aftermarket bumper / winch weight. I would reach out to them and discuss how much additional weight you have added and seek their recommendation.
Note:
The springs job is the hold up the weight, and the shocks job is the control it. If you have the wrong spring rate, the shock is going to have a hard time controlling that weight regardless.
Old 09-03-2019, 06:03 PM #7
LT1coupe's Avatar
LT1coupe LT1coupe is offline
LT1coupe will become famous soon enough
LT1coupe's Avatar
FJ 4x4 coils set at 1.75 gave me about 2.250" lift & are significantly stiffer, very inexpensive.
Ride is firm not harsh.
2006 V8 Sport 4wd conversion, ADD front axle, FJ twin stick transfer case, premium long tubes, truetrac ,5100's, FJ springs
LT1coupe is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 06:39 PM #8
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
Run the Dobinsons 700lb front springs, trash those spacers, set the Bilsteins either at the middle setting or 1 notch above that.
Running stock springs from any vehicle is going to ride like garbage.
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 06:57 PM #9
Bumbo's Avatar
Bumbo's Avatar
I still don’t think it’s enough spring to handle the additional weight of the V8 + a bumper.
Googling shows a shipping weight of about 285 lbs for the ARB bumper, so estimate at least 200 lbs installed + accessories if applicable.
Plus coils are pretty inexpensive as it is... couple hundred for new and you get something you know will work. Certainly cost more to do it twice.
Old 09-03-2019, 07:58 PM #10
LT1coupe's Avatar
LT1coupe's Avatar
They're 660# springs, but I'm not running an aftermarket bumper yet so I can't vouch for the extra weight.
Old 09-03-2019, 08:07 PM #11
Bumbo's Avatar
Bumbo's Avatar
It’s stiffer than I thought it would be, so that’s great to know it’s #660.
From the reading I have done on the 6112/V8 threads, many people appear to be pairing the Eibach #650 for use with the V8 without front bumper.
Sounds like the OP should be looking for at least a #700 coil, but that’s my guess. Again, I would call Eibach and run it by them, their team is pretty good at handling these types of questions. They have been very helpful in the past on my off-road vehicles.
Old 09-04-2019, 07:11 AM #12
Dobinsons has a 730# option that would probably be a little better for the bumper plus a V8. As far as I know they're the only ones who surpass the 700# mark. OP, If you're ever planning on putting a winch on or if it has one already go with the 730# springs. You wont be disappointed.
Old 09-04-2019, 07:14 AM #13
King can provide you with a 750lb spring, which is what I will be swapping to when running a front bumper and winch
Old 09-04-2019, 07:23 AM #14
Holy shit, if that’s the correct weight, don’t go with anything less than 700 lb springs.
More important than preventing g the front end from sagging, it’s a safety issue. Without properly supporting all of that extra weight, emergency maneuvers will be compromised, as well as emergency brake g
Old 09-04-2019, 11:16 AM #15
Thanks for the quick educational read on coil spring rates and load capacities. I'll see what I can do to expedite proper coils to match the weight. I plan on adding a winch, warn xd900i or warn 8274 modified to fit the bumper so I'll take that extra weight into consideration.
arb , bilstein , bumper , front , hat
5100's + Moog 81108 + Demello front bumper. What 5100 setting? HustleHard 4th Gen T4Rs 3 01-23-2017 07:41 PM
Front Bilstein 5100 kenlainpro_ 4th Gen T4Rs 3 10-16-2015 04:27 PM
Wtb bilstein 5100 adjustables front and 5100 rears yotamaine For Sale: Suspension/Wheels/Tires 0 04-08-2015 05:04 PM
Bilstein: tundra front adjust. strut and oem coil? bpowa 3rd gen T4Rs 21 09-07-2014 09:10 PM
Bilstein 5100 front adjustable shocks or front spacers? sporty87 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 11-19-2010 08:13 AM
